GTSBoy Posted June 15, 2018 Share Posted June 15, 2018 You might ask Haltech what could be done to the ECU to permit the use of the PRP triggers. It might be possible. Link to comment https://www.sau.com.au/forums/topic/474276-planning-rb28-build-need-suggestions/page/2/#findComment-7878315 Share on other sites More sharing options...
Dose Pipe Sutututu Posted June 15, 2018 Share Posted June 15, 2018 22 minutes ago, GTSBoy said: You might ask Haltech what could be done to the ECU to permit the use of the PRP triggers. It might be possible. Yeah need to go PS2000 or Elite series is the only real option, the trigger settings for the Pro Plug-ins are hard coded (if memory serves me correctly). Link to comment https://www.sau.com.au/forums/topic/474276-planning-rb28-build-need-suggestions/page/2/#findComment-7878318 Share on other sites More sharing options...
GTSBoy Posted June 15, 2018 Share Posted June 15, 2018 1 hour ago, Dose Pipe Sutututu said: Yeah need to go PS2000 or Elite series is the only real option, the trigger settings for the Pro Plug-ins are hard coded (if memory serves me correctly). Yes, but my thought is that Haltech are on of those crowds that occasionally do special firmware for their ECUs, if you ask nicely enough. Link to comment https://www.sau.com.au/forums/topic/474276-planning-rb28-build-need-suggestions/page/2/#findComment-7878325 Share on other sites More sharing options...
Dose Pipe Sutututu Posted June 15, 2018 Share Posted June 15, 2018 19 minutes ago, GTSBoy said: Yes, but my thought is that Haltech are on of those crowds that occasionally do special firmware for their ECUs, if you ask nicely enough. Doesn't hurt to ask I suppose I know Andy at Adaptronic back in the day happily wrote custom firmware for me, top bloke! Link to comment https://www.sau.com.au/forums/topic/474276-planning-rb28-build-need-suggestions/page/2/#findComment-7878329 Share on other sites More sharing options...
niZmO_Man Posted June 17, 2018 Share Posted June 17, 2018 On 6/15/2018 at 5:12 PM, Dose Pipe Sutututu said: Doesn't hurt to ask I suppose I know Andy at Adaptronic back in the day happily wrote custom firmware for me, top bloke! That's some customer service! Link to comment https://www.sau.com.au/forums/topic/474276-planning-rb28-build-need-suggestions/page/2/#findComment-7878483 Share on other sites More sharing options...
etang789 Posted July 28, 2018 Author Share Posted July 28, 2018 On 6/15/2018 at 1:23 PM, Dose Pipe Sutututu said: Yeah need to go PS2000 or Elite series is the only real option, the trigger settings for the Pro Plug-ins are hard coded (if memory serves me correctly). I emailed Haltech and their reply is the following Quote The Pro model supports the factory CAS and also the kits that use a 12x tooth crank and 1x tooth cam trigger. So those kits look fine. It is just a setting in your Ecu to change it over. Link to comment https://www.sau.com.au/forums/topic/474276-planning-rb28-build-need-suggestions/page/2/#findComment-7882118 Share on other sites More sharing options...
etang789 Posted January 22, 2019 Author Share Posted January 22, 2019 I cannot decide which cams to go with especially when 8474 is going to available soon. I want response but don’t want to give up all the top end. Tomei 260Degree 10.8mm lift Intake Tomei 260Degree 10.8mm lift Exhaust Or HKS V Cam Step 1 248Degree 8.6mm Lift Intake Mines 252Degree 10.05mm Lift Exhaust Or Mines 252Degree 10.05mm Lift Intake Mines 252Degree 10.05mm Lift Exhaust Or Unigroup 258Degree 11mm Lift Intake Unigroup 258Degree 11mm Lift Exhaust Link to comment https://www.sau.com.au/forums/topic/474276-planning-rb28-build-need-suggestions/page/2/#findComment-7896871 Share on other sites More sharing options...
WR33KD Posted January 23, 2019 Share Posted January 23, 2019 Quick question, have you dat down with an engine builder and talked about what you want? Sounds like a catalogue car that will sound cool on paper but will have a crap ton of lag and go no where fast. Your head is where your power is going to be made and running cam numbers off like that doesn’t mean anything until your dead set on a turbo and a power goal. I spent 3 months talking to people and reading about turbo vs cam specs before I jumped in the deep end with my builder. PS there was a purple r33 GTR here in NZ that was a book car and it was nothing special once you drove it, HKS here Greddy there, no power delivery 1 Link to comment https://www.sau.com.au/forums/topic/474276-planning-rb28-build-need-suggestions/page/2/#findComment-7896930 Share on other sites More sharing options...
NEO25T Posted January 23, 2019 Share Posted January 23, 2019 On 7/29/2018 at 3:35 AM, etang789 said: I emailed Haltech and their reply is the following Yep can use it with platinum pro but as previously suggested I would go elite if I were u Link to comment https://www.sau.com.au/forums/topic/474276-planning-rb28-build-need-suggestions/page/2/#findComment-7896947 Share on other sites More sharing options...
etang789 Posted January 23, 2019 Author Share Posted January 23, 2019 (edited) 2 hours ago, WR33KD said: Quick question, have you dat down with an engine builder and talked about what you want? Sounds like a catalogue car that will sound cool on paper but will have a crap ton of lag and go no where fast. Your head is where your power is going to be made and running cam numbers off like that doesn’t mean anything until your dead set on a turbo and a power goal. I spent 3 months talking to people and reading about turbo vs cam specs before I jumped in the deep end with my builder. PS there was a purple r33 GTR here in NZ that was a book car and it was nothing special once you drove it, HKS here Greddy there, no power delivery Yes I have talked to a few different builders. I am set on EFR 8374 1.05 or 8474 if available. I’m just trying to reuse most of the parts that came with the car. And since theres no shop capable to doing any custom work over here in Hong Kong, I need to use of the shelf items aka exhaust...etc Edited January 23, 2019 by etang789 Link to comment https://www.sau.com.au/forums/topic/474276-planning-rb28-build-need-suggestions/page/2/#findComment-7896949 Share on other sites More sharing options...
etang789 Posted January 23, 2019 Author Share Posted January 23, 2019 (edited) 1 hour ago, NEO25T said: Yep can use it with platinum pro but as previously suggested I would go elite if I were u Yea I figured out that setting. I’m leaning towards Elite but will wait until last minute to decide. Don’t want to be like last time (the build dragged on for 2 years) that Elite came out right after I finally installed the Platinum Pro... Edited January 23, 2019 by etang789 Link to comment https://www.sau.com.au/forums/topic/474276-planning-rb28-build-need-suggestions/page/2/#findComment-7896951 Share on other sites More sharing options...
burn4005 Posted January 25, 2019 Share Posted January 25, 2019 Emtron KV8 is the correct answer. Link to comment https://www.sau.com.au/forums/topic/474276-planning-rb28-build-need-suggestions/page/2/#findComment-7897143 Share on other sites More sharing options...
