22 minutes ago, GTSBoy said:
You might ask Haltech what could be done to the ECU to permit the use of the PRP triggers.  It might be possible.
Yeah need to go PS2000 or Elite series is the only real option, the trigger settings for the Pro Plug-ins are hard coded (if memory serves me correctly).
Yes, but my thought is that Haltech are on of those crowds that occasionally do special firmware for their ECUs, if you ask nicely enough.
Doesn't hurt to ask I suppose :)
I know Andy at Adaptronic back in the day happily wrote custom firmware for me, top bloke!
  • 1 month later...
I emailed Haltech and their reply is the following
Quote
The Pro model supports the factory CAS and also the kits that use a 12x tooth crank and 1x tooth cam trigger.  So those kits look fine.
It is just a setting in your Ecu to change it over.
  • 5 months later...
I cannot decide which cams to go with especially when 8474 is going to available soon. I want response but don’t want to give up all the top end.
Tomei 260Degree 10.8mm lift Intake
Tomei 260Degree 10.8mm lift Exhaust
Or
HKS V Cam Step 1 248Degree 8.6mm  Lift Intake
Mines 252Degree 10.05mm Lift Exhaust
Or
Mines 252Degree 10.05mm Lift Intake
Or
Unigroup 258Degree 11mm Lift Intake
Unigroup 258Degree 11mm Lift Exhaust
Quick question, have you dat down with an engine builder and talked about what you want?
Sounds like a catalogue car that will sound cool on paper but will have a crap ton of lag and go no where fast.
Your head is where your power is going to be made and running cam numbers off like that doesn’t mean anything until your dead set on a turbo and a power goal.
I spent 3 months talking to people and reading about turbo vs cam specs before I jumped in the deep end with my builder.
PS there was a purple r33 GTR here in NZ that was a book car and it was nothing special once you drove it, HKS here Greddy there, no power delivery
  • Thanks 1
Yes I have talked to a few different builders.
I am set on EFR 8374 1.05 or 8474 if available.
I’m just trying to reuse most of the parts that came with the car. And since theres no shop capable to doing any custom work over here in Hong Kong, I need to use of the shelf items aka exhaust...etc
Edited by etang789
1 hour ago, NEO25T said:
Yep can use it with platinum pro but as previously suggested I would go elite if I were u
Yea I figured out that setting.
I’m leaning towards Elite but will wait until last minute to decide. Don’t want to be like last time (the build dragged on for 2 years) that Elite came out right after I finally installed the Platinum Pro...
Edited by etang789
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
