Hey there fellas. I currently own a 180sx fitted with a Greddy Profec A EBC. Immediately after fitting a boost gauge (now a while back), I saw that the needle regularly reached 16psi. This was quite alarming as the EBC was only set to 7psi (stock). After I noticed this, I verified that the boost gauge was working properly and was not faulty, by verifying that the EBC readout also reached 1.0 bar (14psi or thereabouts) as well.
First question; why is the car not holding boost around 7psi as it should? I have a feeling that either the solenoid or the actuator is stuffed. Are these problems common or unheard of? Which brings me to a third question; if the actuator needs to be replaced, is it possible to purchase and fit an actuator separately? Or do I need to replace the whole turbo assembly?
I'm starting to get a bit freaked out that my turbo or engine is going to suddenly explode, so your help is greatly appreciated.
https://www.sau.com.au/forums/topic/47428-overboosting-car-not-holding-boost/
Noticed a similar thing with my 34. It has a Greddy Profec EBC and hand controller(hand controller not hooked up though). The boost is set to around 13-14 psi at max but i regularly see it hit 16psi with the very cold mornings we experience here in Canberra.
I thought an EBC was not supposed to allow this to happen?
Make sure you have completely removed the factory solenoid...
Make sure the EBC is connected properly, and there isnt any leaks.
If so, it should hold boost fine, ive got an avcr, and the worst it ever spikes is 1 psi
:werd: sounds like the solenoid isnt set up right. 2psi spike? damn, the worst my hks evc spikes is 0.02bar (0.3psi)
Everything is set up right, no leaks in hoses and the factory solenoid has been removed completely. The boost is spiking to more than double what it is set to, this is what's scaring me. If it was only 0.1 bar or 1 to 2 psi it would be OK but double the boost says something is definitely wrong.
The only other option I can think of at the moment is to purchase or lease another profec A solenoid to see whether that works or not.
YOYO
It could be that your gain,set gain and set boost are set to high.If these are to high then you will run into overboosting problems.
I dont know how different the profec A is but it should be simpiler to tune.I use a Profec b spec 2 ebc and it was spiking also.
Run it turned off with the controller hooked up and see if the car does the same.
And also try to keep your hose length to a minimum.Have the boost controller located in a cool area of the engine bay not right next to the motor.
Remember start at zero and work your way up.
Trust33 -> I'll have to check those knobs you mentioned. What do the ratio/time/offset knobs actually do? I have these three little knobs to the right of the main boost setting but haven't touched them since purchasing the car.
BTW, I've already tried turning the controller off and it still overboosts, so it's not the EBC's fault.
Low25 -> Yes, the profec A does have an OverTake Boost (O.T.B) button but i don't know how much it increases boost by, it lasts around 10 secs though.
The solenoid wants to reach the set boost but it cant cause uve set it to high. Couple that with a small ass exhaust housing and wastegate that cant handle the exhaust gas flow from the engine and the solenoid wants it to achive all this when it cant cause its SET TO HIGH SO BRING IT BACK TO ZERO.
The unit only reads what you set it to.
Trust33 -> Umm, I've only set it to stock, can't get any lower. I've also tried setting the boost to zero but that didn't work either, the car still overboosts.
rb25 -> I've checked all lines and they are all ok, the controller came as is, installed with the car.
I have a feeling it could be on a different high boost setting, I'm going to check this out tomorrow.
Id suggest that you get a users manual from somewhere.
If you cant find your problem,then you should assume that its your solenoid.
Here you go i may be able to help you.heres a link to a blokes site where he has installed a profec a on his rotary.The diagram shows the points at which the boost controller should be connected.And it is for an internaly actuated wastegate like the one youve got.
http://www.scuderiaciriani.com/rx7/profec_install.html
This is the main page (appendix) to it.
http://64.233.167.104/search?q=cache:cbHl-...df+format&hl=en
This one also has the power fc,avcr and a heap of other manuals and wiring diagrams for peeps to download.
YOYO;
I currently run a Profec A ebc on my r33, have u done the learning mode so that the ebc can learn ur turbo cruve, i was lucky and bought mine off someone how had it on a r33 so it was already set to a stock turbo, so i get no overboosting.
Try to do the learning mode or get it tune by a workshop
I got the manual checked out the settings. Low boost is 5bar and high is 7bar.
Today I took it for a good fang and got the car up to 18psi in 5th!!! Needless to say, I let go of the accelerator pretty quick after that!
13_devil -> how did you get the EBC into learning mode? I've got the downloaded manual, but it doesn't say how.
Well guys got it fixed yesterday (Thanks Faeez, you're a f**king legend!). We played around with the hoses a bit and checked that the actuator opened up the wastegate using a bicycle pump. As it turns out, the piping coming off the intercooler charge pipe to the solenoid had an air filter that was leaking.
Now that it's fixed, the car feels a LOT slower; 7psi is nothing compared to 18!!! Oh, and I don't have an excuse to upgrade my turbo :rofl:
Anyways, thanks for your suggestions ppl.
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
