Hey guys,
Pulled my diff apart today which is a standard viscous LSD to put some shims in. I noticed the right side shim which is 0.8mm has worn and is pitted and warped, the left side isn't as bad and is 1.4mm. When i went to pull the centre out i didn't have to force it much to get it out, so I'm thinking of changing the bearings as well. The diff felt pretty good before i pulled it apart and i was happy with the backlash.
I have read most people are putting in a 0.8mm shim each side on top of the original shim, this seems like a lot of shimming but i just want to here peoples thoughts.
Cheers
https://www.sau.com.au/forums/topic/474287-r200-shimming/
In a completely stock VLSD, the shim does NOTHING except set the clearances.  The viscous cartridge inside the diff does all the "limiting" of the slip.
[Word redacted to avoid insulting people]s who have no understanding of these things like to jam thicker shims into the space between the housing and the centre to jam it all together harder and create a new friction surface outside of the centre.  When it wears, they express surprise and jam another one in there.
The correct thing to do is to f**k the VLSD centre off and put a proper diff centre in there.
https://www.sau.com.au/forums/topic/474287-r200-shimming/#findComment-7878408
