the shimming dosent work well in a viscus diff ive been told by some diff exprts who build them for race cars.
Chris they s13 diff will bolt in 100% some of them use the skyline 5 bolt driveshafts as well, the only think i need to check is the bolts for the hicas rack as not many s13 have the hicas and the rear of the diff may be different
The Unique diff upgrade is still the std viscous diff so can only assume its been re-shimmed?!?!
R31Nismoid do you mind doing me a favour and PM'ing me the price and time to re-shim the std diff, i want to give the car a run down the qtr and a functioning diff would be nice.
Just got to find one at the right price, $1000 for a "i think its a..." is the best i can do. Another guy with a Nismo 1.5 for $500 stopped returning my email when i wanted to pick it up...and freight costs for a new diff from Japan make it too expensive, plus where i dont need to im trying not to lean on friends that have been helping me out with favours & parts so a re-shim is looking good. Patience is a virtue im told.
Clint, so your sure a S13 diff will bolt in no probs? Reason I ask, I can get a Nismo 2 way of a S13, with 5 bolt half shafts for a reasonable price. If you can confirm, I will most likely go down this route
P.S - haven't forgot about the carton I owe you, you gonna be home tomorrow night after about 7?
Cheers, Chris
chris im 99% sure they go in no probs, to only diff is they dont have the hicas mounts now you should be able to swap the rear cover plate with your std diff and all will be sweet, but without looking at them side by side i dont wont to give a deffinate answer
Chris32,
Don't know if this of any interest to you but in the near future I'll be removing my LSD and swaping it back to a stocker since I'm not doing any more track days and it's not really what I want for street use. ( Yes I'm getting old ).
I pulled the back cover off to check the condition of the diff in general and to determine what brand it was when I got it ( it was sold to me ex Japan as a Cusco 1.5 way ? ) and it turned out to be an ATS ( Active Traction Systems, Japan ) 1.5 way which was an extremely cool finding considering the ATS centre kit alone goes for around $1,800. plus shipping and fitting.
Anyway, I'll be looking to get my money back in the sale which is $1,000
It's in my R32 GTS-T at the moment but keep your eyes on the parts for sale page.
Sorry if this is what's considered hijacking a thread ( I really don't understand all these terms ) :(
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
