Hi there!
I have GTX35 + CP Pistons + Bridgeway H-Beam rods + Nitto oil pump + HKS 264 8.7mm + Cometic 1.3mm head gasket + ARP head + rods stud + Harmonic balancer Ross Tuffbond. Head is stock just that cams.
What is the highest safe revlimit on that setup for street car?
  • Like 1
https://www.sau.com.au/forums/topic/474292-forged-rb26-stock-head-revlimit/
Really it's going to come down to whether your setup is still making power up that high. If boost is falling off and the turbo is nosing over then there is no point revving it out.
Being a gtx35 I doubt there will be much of a reason to go too far past 8.
High revs, aftermarket cams and decent amount of boost with stock valve springs won't be revving very high.
You'll most likely end up with valve float and a load of misfires instead.
Not saying they are gospel by any means, but the motiveDVD GT-R just went through this exact query.  They decided to keep to the stock rev limit to preserve of the stock head, stock girdle plate and stock crank.
Pt.2 of 2
Edited by JGTC
On 6/20/2018 at 10:10 AM, GTSBoy said:
I was going to say more than 9000, but that's awfully specific.  Do you have data to back this up?
Yeah, IT'S OVER NINE THOUSAAAANNDDD!!!11!!!!ONE!
One day I'll have enough money to build an RB26 to spin past 9,000 rpm, just so I can ask a passenger "what does the tachometer say about the engine speed?"
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
