Hi All,
Please help me identify any speed issues you may be experiencing.
Do these issues occur at a specific time?
Do they occur on mobile or desktop or both?
Does the status bar (bottom left) say "loading ..." or anything while its loading? If so can you post what it is loading?
Anything else you may have noticed.
Thanks guys, the site has been fine for me so I haven't noticed it at all.
Christian
https://www.sau.com.au/forums/topic/474301-site-speed/
The speed issues im having are mostly when using pc. Mobile  app isn't lightning either but is ok. When on pc in the bottom left corner i get waiting for sau.com and then waiting for google ad services and after about a minute the next page will actually load. I have held off in saying anything till now in the hope it will resolve itself but that hasn't happened.
Cheers Bill
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878509
 Cheers Bill
Thanks Bill,
Can you keep an eye on it over the next day or two and let me know if it seems any better?
Thanks,
Christian
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878510
Thanks Bill,
Thanks,
Christian
No probs, im on mobile app atm and it seems to be faster than before, ill let you know how the pc goes when i get a chance to use it [emoji106]
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878529
I have been having issues connecting to SAU....all other forum sites I visit are fine, just SAU.  I sometimes get the DOS based view [blue text, and just a list of the forum pages] rather than the normal GUI forums page.
If I get the DOS view then I cannot open any other pages, it usually comes up with a blank screen.  If I leave and come back in 10-15 minutes its then usually OK.
The other thing that has just started to happen as well, the forums page comes up OK then it reloads straight away and I get a blank screen [address in address bar is still OK].
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878647
Wow! That all sounds really screwy!
Can you take some screen shots next time? This is really bizarre.
What OS / Browser are you using? Has it been different over the past 24hrs?
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878648
I'll take screen shots when I can...just now had to try to get into SAU 3 times...3rd time lucky.
Was Ok 1 or 2 days ago, didn't notice a difference till this morning tbh.  Still using IE...been lazy,  really should have gone over to Chrome or Edge.  Used to use Firefox but my virus checker was saying FF was out of date etc so gave up on FF.
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878682
10 hours ago, PranK said:
Thanks guys.
I've just made some more changes please keep the feedback coming if anything changes again.
Shortly after you made the quoted post, I could not reply to any threads for the whole afternoon.  The reply box at the bottom was grey and unresponsive.  Highlighting any text in a post did not bring a pop up "quote the selected" and there were no quote buttons anywhere.  I wouldn't normally say anything about this, because it has happened to me many times in the past (and yes, I was logged in), but the timing of you "making some changes" might be more than a coincidence.
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878687
Ok thanks for letting me know. It's some of the coad behind the reply box that has been changed so that makes sense but please let me know if it happens again (if it happens you can get me via the contact form or even via the Facebook page if PM's don't work).
https://www.sau.com.au/forums/contact/
Thank you!
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878688
  • 3 months later...
Thank you!
PM sent
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7886029
For the last week and a bit ive been having issues where new and unread posts aren't showing. This is across the main site, app or Tapatalk. Sometimes a notification will show a new post but nothing is on site. Eventually when the posts show up, i can see there was posts made at the times i was not able to see anything. Im wondering if this is widespread or just happening to me.
Please check it out when you get a chance Prank. Thanks Bill [emoji106]
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7886475
Yep seeing this too in the Android app.
Also experiencing this in the all posts view. No posts appear and then the posts sometimes appear after refreshing 10 times.
Rob
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7886529
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
