Hi All,
Please help me identify any speed issues you may be experiencing.
Do these issues occur at a specific time?
Do they occur on mobile or desktop or both?
Does the status bar (bottom left) say "loading ..." or anything while its loading? If so can you post what it is loading?
Anything else you may have noticed.
Thanks guys, the site has been fine for me so I haven't noticed it at all.
Christian
https://www.sau.com.au/forums/topic/474301-site-speed/
The speed issues im having are mostly when using pc. Mobile  app isn't lightning either but is ok. When on pc in the bottom left corner i get waiting for sau.com and then waiting for google ad services and after about a minute the next page will actually load. I have held off in saying anything till now in the hope it will resolve itself but that hasn't happened.
Cheers Bill
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878509
 Cheers Bill
Thanks Bill,
Can you keep an eye on it over the next day or two and let me know if it seems any better?
Thanks,
Christian
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878510
Thanks Bill,
Thanks,
Christian
No probs, im on mobile app atm and it seems to be faster than before, ill let you know how the pc goes when i get a chance to use it [emoji106]
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878529
I have been having issues connecting to SAU....all other forum sites I visit are fine, just SAU.  I sometimes get the DOS based view [blue text, and just a list of the forum pages] rather than the normal GUI forums page.
If I get the DOS view then I cannot open any other pages, it usually comes up with a blank screen.  If I leave and come back in 10-15 minutes its then usually OK.
The other thing that has just started to happen as well, the forums page comes up OK then it reloads straight away and I get a blank screen [address in address bar is still OK].
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878647
Wow! That all sounds really screwy!
Can you take some screen shots next time? This is really bizarre.
What OS / Browser are you using? Has it been different over the past 24hrs?
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878648
I'll take screen shots when I can...just now had to try to get into SAU 3 times...3rd time lucky.
Was Ok 1 or 2 days ago, didn't notice a difference till this morning tbh.  Still using IE...been lazy,  really should have gone over to Chrome or Edge.  Used to use Firefox but my virus checker was saying FF was out of date etc so gave up on FF.
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878682
10 hours ago, PranK said:
Thanks guys.
I've just made some more changes please keep the feedback coming if anything changes again.
Shortly after you made the quoted post, I could not reply to any threads for the whole afternoon.  The reply box at the bottom was grey and unresponsive.  Highlighting any text in a post did not bring a pop up "quote the selected" and there were no quote buttons anywhere.  I wouldn't normally say anything about this, because it has happened to me many times in the past (and yes, I was logged in), but the timing of you "making some changes" might be more than a coincidence.
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878687
Ok thanks for letting me know. It's some of the coad behind the reply box that has been changed so that makes sense but please let me know if it happens again (if it happens you can get me via the contact form or even via the Facebook page if PM's don't work).
https://www.sau.com.au/forums/contact/
Thank you!
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7878688
  • 3 months later...
Thank you!
PM sent
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7886029
For the last week and a bit ive been having issues where new and unread posts aren't showing. This is across the main site, app or Tapatalk. Sometimes a notification will show a new post but nothing is on site. Eventually when the posts show up, i can see there was posts made at the times i was not able to see anything. Im wondering if this is widespread or just happening to me.
Please check it out when you get a chance Prank. Thanks Bill [emoji106]
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7886475
Yep seeing this too in the Android app.
Also experiencing this in the all posts view. No posts appear and then the posts sometimes appear after refreshing 10 times.
Rob
https://www.sau.com.au/forums/topic/474301-site-speed/#findComment-7886529
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
