Hae all so im replacing my wheel bearing on my 1993 r32 and its been a complete nightmare. So i originally bought a bearing off ebay for a r32 as pictured451394808_Screenshot_20180611-174953_SamsungInternet.thumb.jpg.ee0f9ae64a3cbda25b225d1ae02e52bd.jpg
Then once apart i come to realise its wrong and its this type20180611_173717.thumb.jpg.1028eb28a7d1684f5009aa3c71c4a3a9.jpg
Now after alot of searching i come to the assumption i have a type m? Because i have 4pot brakes on front 2pot on the rear and digital climate control. i eventually found a bearing through bursons it came up as a r32 gtr drum handbrake type so i got it, fitted it up and the inner diameter for the cv spline is to big. Can some one please tell me exactly which one will fit because the lady at bursons said there were no other listings for a 32 apart from what i bought from them and the original one i bought. Need one by the weekend. Thanks
https://www.sau.com.au/forums/topic/474302-need-help-with-r32-bearing/
Assuming your car is 2wd (since you don't say, and neither does your profile) not 4wd?
When you say you "fitted it up and the inner diameter for the cv spline is to big" do you mean you can't press the hub face back into the bearing because it is too large, or because it is too small/loose or something else?
If you post up your VIN# someone can look up the exact nissan part# in FAST for you.
Sorry it is a 2wd and it came as a hub and bearing assembly. So when i went to push in the cv shaft it just spins without meshing to the splines
1 minute ago, Duncan said:
Ok...so you are correct, it is a type M.
Sik_R31 was the winner, part numbers you need are:
43280-30P05 / 43280-AA000, and
43281-30P05 / 43281-AA000
Excuse my ignorance but whats Sik_r31?
Those part numbers will i be able to use to them at a place like bursons?
sorry, Sick_R31, not Sik_R31
On ‎6‎/‎18‎/‎2018 at 10:24 PM, Sick_R31 said:
Bursons may not be able to use those numbers, they are a Nissan part number so they would need a cross check. You could buy from Nissan or Kudos as per Sick_R31's link. Or Amayama.com if you are not in a rush.
Alright sweet as thanks heaps ?
  • 3 months later...
Bumping this thread, trying to get out the hub out from the knuckle after removing the entire assembly from the car...
I clamped the knuckle to a piece of wood, stood on it and went at it with my sliding hammer as hard as I could. Nothing besides me and the entire knuckle/wood thingy moved a single mm.
Just want to verify, the snap-rings are only there to hold the bearing, right?
Any options besides more heat, more lube and more force?
    • bump. Anyone had this done? either 49 or 50mm? Been pondering what to do while mines in storage. Been thinking of DBW but if I do that, then might as well do this too. Want to retain 6 throttles. I have a fully build head(CNC, OS valves, 286/278 cams, etc etc still running squish), and a Greddy old school intake with port matching. Head bench flowed 300cfm. Wondering whether bigger throttles will give me any gains. Makes 563kw.
    • If anyone has any suggestions for a 300-350mm long (or thereabouts) muffler that is 3inch in and out I'm listening
    • It's the same with many brands that find their way into promotion via Youtube channel sponsorships. Those stainless guys, e-mail cut shippit, various other service and product companies.... they try to make it so that the only name that comes to mind when you think of doing those things is them, and then you just go get their stuff because your favourite channels are using it, so it must be good AND good value. Notwithstanding that the YT'ers don't pay anything for it. But a lot of people are not that sophisticated.
    • Yeh vibrant looks a bit overpriced, but thats the US market in general, they pay $50k for a gtst...
    • It's surprising you say this because talking to someone who headed Toyota's CARB certification efforts and was now working for Mercedes doing similar things he said he never had a case where he found that it was necessary to reduce ignition timing for that reason. Knock limits yes, but never because of in-cylinder emissions profile. I'm guessing between EGR and the number of TWCs modern cars stack in series it's not really a problem. I really doubt the NEO is that big a difference. You get what, EV6 injectors, coil on plug, a cold start valve that works off coolant temp instead of basically fixed time constant valve, and... I really can't think of anything else. Not like Toyota where they shipped first gen GDI in the 2JZ-FSE.  Something I didn't realize is that Japan didn't revise their emissions standards for light duty passenger cars between 1978 and 2000. I'm guessing there's a bit of phase-in, but that explains why 2002 killed a bunch of JDM sports cars off all at once. FD3S, A80, S15, Z32, R34, Z15A GTO all died off for that reason. And explains how all these cars got away with no EGR or much of anything other than a TWC and charcoal canister for the longest time.
