HiAll,
I'm wondering if anyone can help me please, I'm trying to test my RB25 CAS (Mitsubishi unit) and results are as follows. (Testing with CAS plugged in rotating by hand)
Pin 3 seams to read 0.5v whenever shaft is turning and drops to 0.1v - 0.0v when stopped.
Pin 4 cycles between 0.9v and 0.1v every few millimeters when turning shaft, and voltage holds wherever I stop it.
I'm assuming this functioning correctly, but I cant find anything to confirm.
This is in a RB25/30 in a R32 using a wolf V550  and I can't see any CAS signal or RPM input when I attach my laptop. I'm about to send my wolf ecu to be tested.
Thanks
https://www.sau.com.au/forums/topic/474313-cas-test-please-help/
Sorry, I've mad a mistake with the Pin numbers.
Pin 2 seams to read 0.5v whenever shaft is turning and drops to 0.1v - 0.0v when stopped.
Pin 1 cycles between 0.9v and 0.1v every few millimeters when turning shaft, and voltage holds wherever I stop it.
