darksould43 Posted June 21, 2018 Share Posted June 21, 2018 any idea on how to do a burnout in a 300 rx stagea? it doesnt have traction control or anything but every time i try all the engine does is rev to 2000rpm and nothing else, i hold the brakes just enough to stop the car rolling and try to rev the engine but nothing, what am i doing wrong, i can try chaining it to a pole but id rather not atm Link to comment https://www.sau.com.au/forums/topic/474324-stagea-m35-burnout/ Share on other sites More sharing options...
KiwiRS4T Posted June 21, 2018 Share Posted June 21, 2018 Drop in an LS7 or put some bald, skinny tyres on the back. Link to comment https://www.sau.com.au/forums/topic/474324-stagea-m35-burnout/#findComment-7878866 Share on other sites More sharing options...
Ben C34 Posted June 21, 2018 Share Posted June 21, 2018 Hahahjaja even a v6 commodore can do a burnout! Hahahhaa put an ecotec in it mang Link to comment https://www.sau.com.au/forums/topic/474324-stagea-m35-burnout/#findComment-7878868 Share on other sites More sharing options...
Leroy Peterson Posted June 21, 2018 Share Posted June 21, 2018 Too much grip, needs single pegger like the pros Link to comment https://www.sau.com.au/forums/topic/474324-stagea-m35-burnout/#findComment-7878872 Share on other sites More sharing options...
Duncan Posted June 21, 2018 Share Posted June 21, 2018 take it to a dealer, swap it for a c34 stagea and you should be fine 2 Link to comment https://www.sau.com.au/forums/topic/474324-stagea-m35-burnout/#findComment-7878887 Share on other sites More sharing options...
Burger Posted June 24, 2018 Share Posted June 24, 2018 Needs more space savers 1 Link to comment https://www.sau.com.au/forums/topic/474324-stagea-m35-burnout/#findComment-7879023 Share on other sites More sharing options...
Hertz Donut Posted June 25, 2018 Share Posted June 25, 2018 On 6/21/2018 at 11:25 PM, Ben C34 said: Hahahjaja even a v6 commodore can do a burnout! Hahahhaa put an ecotec in it mang ^Truth. I took mine to the wrecker a couple of weeks ago and engaged in some private road testing along the way. Smoking a 235/40R18 was ridiculously easy, even with 305,000km of abuse on the clock. Instantly regretted getting rid of it. PS: My new Leaf loses traction if I nail it from a standstill. What am I doing wrong? Not enough shopping bags in the boot? Link to comment https://www.sau.com.au/forums/topic/474324-stagea-m35-burnout/#findComment-7879180 Share on other sites More sharing options...
sideburnie Posted July 7, 2018 Share Posted July 7, 2018 Just checking, but you all know about the throttle cut out from the ECU with brakes on right? NM35 all have that problem due to ECU having a throttle restriction when brakes are on and I think for about 3 seconds after brake release. I would assume PM35 is the same? Solution is the brake wire cut/switch mod (look for it on forums). I did mine - very easy to do. Better option is to get a re-flach of the ECU - some on ebay for NM35 - Nm35 stagea vq25det stage 1 ecu reflash its-rom Link to comment https://www.sau.com.au/forums/topic/474324-stagea-m35-burnout/#findComment-7880389 Share on other sites More sharing options...
Caleb_M35 Posted July 10, 2018 Share Posted July 10, 2018 Foot-on skids are a no go without the above recommendation. Tip it in while in Tip-Tronic 2nd and have some fun Link to comment https://www.sau.com.au/forums/topic/474324-stagea-m35-burnout/#findComment-7880691 Share on other sites More sharing options...
darksould43 Posted July 16, 2018 Author Share Posted July 16, 2018 On 7/7/2018 at 12:19 PM, sideburnie said: Just checking, but you all know about the throttle cut out from the ECU with brakes on right? NM35 all have that problem due to ECU having a throttle restriction when brakes are on and I think for about 3 seconds after brake release. I would assume PM35 is the same? Solution is the brake wire cut/switch mod (look for it on forums). I did mine - very easy to do. Better option is to get a re-flach of the ECU - some on ebay for NM35 - Nm35 stagea vq25det stage 1 ecu reflash its-rom awesome ill give that a go cheers Link to comment https://www.sau.com.au/forums/topic/474324-stagea-m35-burnout/#findComment-7881116 Share on other sites More sharing options...
