You are missing a grub screw. The gate has 2x sets of boost reference ports which are located on the top and bottom of the diaphragm.
You only need to use 1x of each from the top and bottom (as you have) and block the other ones not used as these are used to hook up in parallel additional gates.
There is nothing wrong with how the gate is mounted and the size of it.
  • Like 1
  • Thanks 1
10 hours ago, Eager said:
1.4 is my target on 97 Ron fuel but if it seems reliable I’ll possibly try 1.5, i don’t want to forge the engine however so baby steps I guess. What’s the opinion ? On a safe level for a unopened neo
If you're achieving 465rwhp the in-cylinder pressures are getting up there.
With good tuning the pistons/rods ought to survive. But the OEM head gasket with a bit of age might not be that long lived if the car sees a lot of heavy duty use.  MLS type + head stud kit would be worth looking at IMO.
Tune will dictate what's "safe".
Hi dale cheers for reply
Ye, I have now replaced that grub screw, at the tuning shop we didn’t have any handy so took me a day or 2 to find a 1/16thNPT grub screw, but it’s sorted now
so just waiting to get a bit of free time possibly Friday to reset the controller and go through the steps
to add however that 465 is at crank, I’m in the UK and most tune companies measure at crank so it’s not rwhp man, sorry for confusion
Typical pommies lol
I work with a bunch of them
I am surprised your tuner continued to tune the car as is without the top section of the gate properly plumbed up. I would have only ran a boost reference to the lower port and inverted the EBC operation instead of pushing through with the way it was (which could have ended badly with poor boost control).
  • Haha 1
24 minutes ago, Eager said:
With the gate properly plumbed is that likely to combat my creep too ? It would be nice to hold a fairly steady 1 bar as per spring
ill try get a few hours spare to set the controller up over the next few days
Very likely
  • Thanks 1
  • 4 months later...
SO to bring this back up
the car was re-tuned by a second tuner, who has left my evc turned off, as again the setup was creeping. I did have the boost controller working but he seen no point leaving the evc on as the turbo was creeping on its own to the area of boost intended to run. I maxed out my fuelling so the 570 injectors will be coming out, to allow beyond 1.3/1.4 bar of tune. He also thinks a precision wastegate will solve the creep,
The creep is giving a very linear delivery rather than coming on boost harder.
I had similar issues on 6 boost single pulse T3 manifold same style as yours. Running a smaller turbocharger with a 45mm turbosmart external gate. It kept on creeping as engine revved out with a 14psi spring, no boost controller. In saying that I have seen the same turbo working with a 45mm gate with a different manifold. I think its more less the way of where and the angle of the gate is mounted on the 6 boost causing this problem. I guess easiest solution would be moving on to bigger gates.
41524267_291708348276497_478800846188131
Edited by hypergear
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
