Alright so my r32 with a s2 rb25det started pinging at about half to 3/4 throttle in 3rd a little bit when i turned the boost up to 9psi with a boost t. I installed a adjustable fpr and up the pressure slightly to about 40psi. The pinging stopped but at a drift day i was at yesterday i noticed it doing it under hard acceleration in second gear. The car is stock apart from the basic fmic exhaust boost t and fpr. Any ideas on what could be causing it? Timing was checked a while ago and it was correct. Only started doing it since the boost was set at 9psi
https://www.sau.com.au/forums/topic/474344-rb25det-ping-under-hard-throttle/
factory base pressure for fuel is actually 43.5psi aka 3 bar so you're actually leaning out the car :)
Also if you want to fix your issue, time for an aftermarket ECU or a Nistune. Conveniently I have an Adaptronic 440D Select Plugin for sale if you wish to sort out your tune with an appropriate tuner.
This means you also can ditch your AFM, run any BOV you wish too.
Oh really? From what i read 43psi was the max you could go. Ill set it to 43.5psi and see how i go. I intend on getting a nistune but gonna pull my engine soon and freshen everything up before i get a ecu.
Yep set it to 45psi with the hose off as stated above. Also imo you shouldn't be upping the boost on an rb25 with a stock ecu, many people do, however they run an assload of ignition timing from factory. If by any chance you are running lean then this can cause pinging very easily.
Hell i only run 10° coming onto boost ramping up to 12° on mine with an ATR45SS on 16psi. Stock R33 runs over 20° in some high load cells, I'd keep it at 7psi till you can afford to tune it
Oh i never new that. Thanks man
They might run a lot of timing at stock boost, but by the time you wind the boost up towards 10 psi the ECU starts to access the top right corner of the maps, where there is a shit ton of fuel and a massive retard of the timing.  R&R is built right into the maps.  Well, it certainly is on Neo maps, which I can see in Nistune, so I have no doubt that it was done that way on the vanilla ECU also (which I can't see in Nistune).  And even if it isn't done that way on the vanilla ECUs, it still happens.  So R&R is Nissan's self-protection mechanism to stop people from grenading stock engines.  Crude and effective.  But it can still all go wrong if the fuel pressure is not right (dud reg, or dud pump, etc) because lean will still ping, even with retarded timing.
Basically, it's not good to wind the boost up on them without having a fix for the ECU.  You can only squeeze a little more out of them before the fun police step in.  The worst thing is, you wind the boost up and it feels faster than stock.  So you wind up a bit more and eventually the placebo effect tells you that it's still going faster, but before too long any extra boost just results in massive fuel consumption and no more speed.
Yea i dont plan i winding it anymore i definitely do notice a little difference from 7-9psi though. But in saying that i dont thrash it round everywhere as it is my daily and like you said dont want to wreck my fuel economy. I get 500km out of a tank give or take 50km depending on how its driven.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
