hello all, I have done a bit of searching and am yet to find the answers I seek, I am wanting to get the Nistune upgrade done as soon as possible, to go with the new high flow hyper gear and injectors etc that will be getting installed very shortly, yet I seem to be having issues in finding a reliable installer and tuner that will respond, I've heard many good things about a certain tuner on the eastern side of Melbourne but after 4 attempts at contacting them to see when I'd be able to make a booking etc I have given up and am seeking recommendations, even after I sent them at their request the list of mods that are currently done, as well as what is about to be done to the car, still only got crickets from their end.....I am from Ballarat about 1 1/2 hours drive west from Melbournistan, and don't mind travelling for the right shop .
car is a series 2 RS4 tiptronic auto Stagea, so come on peoples hit me up with some recommendations
I don't know if it is still the case (get on the phone and find out) but I believe Nistune will install their chip on your ecu -courier both ways shouldn't take too long. As to tuners - the best usually have no shortage of customers so if you want the best be prepared to persevere with your efforts. Should be easier if you already have the chip installed and just need the tune.
ok cheers for that, once the Nistune is installed onto my ecu I'm guessing it wont be drivable anyway because of the new injectors, turbo , AFM etc, so either way it'll need to be trailered/tilt trayed to the tuner, but what you have suggested may save a bit of time
Nistune may install a start up tune that will enable you to drive carefully to the tuner if you give them all your details.
5 hours ago, Leroy Peterson said:
If youre still interested in eastern suburbs, CMS is easily contactable and is a Nistune distributor. Shane has a background in electronics and does install nistune boards.
cheers for that, would kinda prefer something on the western side , but will keep them in mind
20 hours ago, oxford1327 said:
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
