37 minutes ago, Dose Pipe Sutututu said:
NA tune, $1.1k for that extra 6.245kW
With my exhaust a massive 10-20 killerwasps is possibly achievable, maybe,for a engine that makes around 100rwkw even an extra 10 to 20% power increase would be good.
But really its the midrange that gets a good lump more of the powers.
Plus I miss rev match, and launch control and flat foot shifting is novel..
Also, I wish it was 1.1k, so far one joint at Marrickville wants 1.4k, and one at Menai wants 1.5k, so about $100 per maybe Kw's.
I've had work done at Menai before and I like the cut of their jib, aaarrrrrrr.
  • 3 weeks later...
Booked in at Pulse Racing for tune, finally.
06 March at this stage, unless a earlier opening pops up.
Car is going flawlessly and handling like a dream.
Common sense prevailed IRT boost, I would be better of just buying something already fast, after owning the boat (33) with it's lotsa hp and fat torques, anything under 500hp and lotsa torques feels  slow.
So for now it's slow and low in the 86.
I am looking forward to getting the car tuned, I will see "some" NA gains, but really, the rev match, flat foot shifting and launch control from Ecutek is awesome , not that it makes me any quicker, but the noises and stuff makes this old guy smile, alot.
The other bonus of staying NA is the minimal worry about reliability, I can thrash the guts out of it and not worry about putting bay windows in the block or melting pistons, breaking rods, eating gearboxes and clutches.
Silver linings and shit.
  • Like 2
On ‎2‎/‎8‎/‎2019 at 7:57 PM, mlr said:
The other bonus of staying NA is the minimal worry about reliability, I can thrash the guts out of it and not worry about putting bay windows in the block or melting pistons, breaking rods, eating gearboxes, clutches and breaking an oil pump + grenading your motor afterwards
FYP :)
7 hours ago, Dose Pipe Sutututu said:
FYP :)
I would be wary about making that assumption IRT the FA20 oil pump.
"Apparently" when in the high rpm range and high oil temp the oil pump tends to cavitate enough to form pitting and a good drop in pressure, worst case senario is lunching oil pump gear.
You can up the oil weight to keep it up a bit, but there are the usual issues with a higher weight oil, more temp, OEM recommend 0w 20, I use 5w 30 (toyota recommend this for "extreme conditions", which I assume equates to my normal driving).
Reality wise, it won't be a issue for me, but, if you are building a track car it may be something to think about, well, mainly oil weight and temp control, from googling around there isn't any real fix for the cavitation at high rpm short of a exy dry sump solution.
Hell, in the end the FA20 is a cheap econobox power plant, it goes good for what it is.
1 hour ago, Dose Pipe Sutututu said:
Haha I thought you were reminiscing about your old R33, hence I added in the blow oil pump part lol
My eye twitches every time I think of my old 33.
It's like a Rorschach test every time I see a oil spill.
  • 3 weeks later...
So, the car goes for its tune next Wednesday, did the oil and filter, shaked out the floor mats and decided to grab a new air filter, the 17+ manual cars have a different airbox and intake design to previous models.
LOL........sooooo, I went past Toyota spares joint and asked if they had a engine air filter, they put in my vin, 17 manual, and then said they had none but could get one shipped next week.
And then...I asked how much...$75AUD, I laughed and said "na mate, just the paper element filter", he checked, got his boss to look and then asked if I want to order it now.
I laughed and walked, strangely the Ryco one I got is near on the same as the Toyota, except the packaging that is, the Ryco cost me $35 at Repco, and you can pick one up for $20 on fleabay.
There is a difference in the number of pleats, but not alot, it is still a big improvement on the crap cotton filters they used pre 17.
I'm sure the filter will not pose a restriction, even with my massive NA donkey powers and small torques
Also found a awesome icecream factory in Mascot, the daughter and her boyfriend had, something??, not mine didn't care, BUT, I had choc chip, which was awesome, they also sell milk, full tilt hippy shit, $6.00 for just under 1 ltr, LOL, but, my god it's good milk, and it's all mine, no one wants fresh full fat creamy milk, I concider that a win for me.
2 hours ago, Dose Pipe Sutututu said:
My guess, 123.0273480923794873298 kWs
Negative
It has actually got more than I hoped for.
Taking it for a drive shortly to test the rev match, launch abd flat foot shifting.
I'm excited....
Stoked
Near on 22% increase from before tune.
Stock average is around 107-110, so, assumptions.......my exhaust and intake mods gave me around 5-8 extra donkey powers prior to tuning, then KAPOW, another 32 raging donkey powers.
In the end it's around a 25% power gain over stock, I'm stoked.
I was hoping for 125ish, did I say I'm stocked.
You can really notice it too, the car really wants to rev now, before, not so much.
Launch control if full of LOLS, same same for flat foot shifting, rev match just makes shit easier.
Overall I'm f**kING STOKED in the car now, it still ain't no rocket ship, but it's so much better than stock now its not funny.
  • Like 3
    • Yeah, the thread is only nearly 20 years old.
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
    • Went to a drift practice day at a local circuit (held on the reserve parking area behind the grandstand) for the first time in about 15 years. Some kei cars were drifting as well, a not so surprising Suzuki Carry truck, and two 1st gen Daihatsu Copens that were converted to rear wheel drive(!) using Daihatsu Boon X4 transfer case, prop shaft and rear diff, obviously omitting the front driveshafts. They looked really fun to slide. I heard that they cost "about half" as much as a Nissan Silvia etc to run.  On the track 'Tech M' a local BMW tuning garage had a customer track day. Mainly recent models but there was one E36 which looked ancient among all the current models. It was cool watching the drifting and then turning around and seeing random people thrashing their M3/4s  central-circuit-drift-practice-2025-05-18-long-yt.mp4
    • I prefer it with those wheels (sacrilege?) 😋 Here's a photo of a fully original one for reference. The price is $350K....
    • I would like to keep it around 15k but if I need more to make it reliable and not have to worry about the car breaking I can go more. It's my project car so I'm just trying g to figure out what needs to be in it i know basic things like turbo cams injectors I'm just unsure of the size and the specifics so I'm spending alot of time on Google and its mostly rb25 and rb26 not alot on neo
