38 minutes ago, Dose Pipe Sutututu said:
Extra 2kW up top and -2kW mid range!
Time for me to flash the missus' Tiguan to get it from 162kW to 223kW lol.
Yes, but yesterday I was teaching the boy to do hektic dowies in a local cul de sac.
BTW, what is happening with your beastie?
You win, can't do donuts in the Nazi troop carrier lol.
Umm it's not in the backyard or my mate's shop any more haha... the siet bok is just getting a bunch of fab work done (that costs more than the car itself, I'm such a bad Asian, fk all ROI)
Umm it's not in the backyard or my mate's shoo any more haha... the siet bok is just getting a bunch of fab work done (that costs more than the car itself, I'm such a bad Asian, fk all ROI)
I'm such a bogan, I just had to Google ROI.
  • Haha 2
Cold start is now as loud as balls.
Cold start is for heating the cats up faster and can be tuned out, hopefully soon.
Went for a hour drive to cook off the heat wrap.
I might need a resonator in the front pipe, maybe, maybe not.
Stone guard thingie will go back on after I have heat cycled it a few times and re-torqued it all up.
Sounds hektik, LOL
27 minutes ago, r32-25t said:
Does it sound like a rexy bro?
Like a noisy one mate, like a noisy one.
Honestly, I really like it, it's just verging on being a bit too loud. Maybe get some unwanted attention type of loud.
I'm going to head into the local exhaust shop and see what they can do, a big arse resonator, louvered not perforated, in the front pipe might knock the tone/noise down enough to make me happy.
A 12" louvered hotdog knocked a heap of noise out of my MX5, I'm hoping it does the same for the 86.
  • Like 1
Now with added quietness, with the added benifit of the legalities....
Cold start is still louder then I really like, but, meh.
Normal running it is as loud as my old MX5, but deeper, and not tinny, plus no drone.
Chopped a turbo Nissan coming back, shallow victory though, it was a SSS.
  • Like 1
3 hours ago, Dose Pipe Sutututu said:
Line you up in the missus' fully taboulli Tiggy
SAU should do another drag day at WSID.
I went to one years ago with my boat (R33 GTST) and chopped everything, excellent day it was.
I would do another in the 86 for the LOLS alone, chopping some other daily drivers would be a bonus.
I'll buy the donuts.
I'll bring both cars, R33 will blow a gearbox then the Tiggy probably blow the haldex, DSG, motor, entire Canbus network will die and the car will light up 1500 error codes (thank fk it's under warranty)
  • Haha 2
Cold start was still to loud
So, now, my current exhaust is a Tomei UEL header, Ultrex 2.5" overpipe, OEM front pipe back.
Going to the smaller pipe isn't a worry as calculations say that 2 1/4" will flow more than enough NA.
And the OEM front pipe will flow the power its making without much of a issue and will save the kittens and frogs for future generations, which is a bonus.
In all honesty I wish I just did the header and overpipe to start with.
Or, stayed with the decat OEM header, 2 5" catless overpipe and 2.5" cat back, the only issue with that is the trail of dead kittens and frogs in my wake.
Like all things it was a lesson, albeit a slightly costly one.
Dooh.
  • 3 weeks later...
Had a play.
Punched out cat in front pipe.
Tomei UEL header showed no gains over the punched out OEM header.
Hell, the punched out OEM cats with the 2.25" OEM stuff showed typical performance to the Tomei UEL with 2.5" catless exhaust.
There is only so much NA powers you can wring from a 2.0 ltr boxer POS.
I will be reinstalling the punched out header and selling the Tomei.
Making more noise for no extra performance is pointless.
Yes I'm getting old...
I'm keeping this little puppy though, but, I have a itch that needs to be scatched.
Some cheap old POS might end up in the yard, the plant yard to be specific....at work.......hidden......from "her"
  • Haha 2
Until you start spending more time at "work"
12 minutes ago, mlr said:
Had a play.
Buy something cheap, like an 80 series cruiser. And shove a Barra turbo in it.
From memory get Barra after June 2006, and it'll happily make 500kw.
So then wind the boost in, injectors, FMIC, and go rip skids.
Even better run the ZF6 gearbox and turn the cruiser RWD just for the drag racing Lols.
I reckon you can easily get a 80 series into the low 12s in that combo.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
