38 minutes ago, Dose Pipe Sutututu said:
Extra 2kW up top and -2kW mid range!
Time for me to flash the missus' Tiguan to get it from 162kW to 223kW lol.
Yes, but yesterday I was teaching the boy to do hektic dowies in a local cul de sac.
BTW, what is happening with your beastie?
You win, can't do donuts in the Nazi troop carrier lol.
Umm it's not in the backyard or my mate's shop any more haha... the siet bok is just getting a bunch of fab work done (that costs more than the car itself, I'm such a bad Asian, fk all ROI)
Umm it's not in the backyard or my mate's shoo any more haha... the siet bok is just getting a bunch of fab work done (that costs more than the car itself, I'm such a bad Asian, fk all ROI)
I'm such a bogan, I just had to Google ROI.
  • Haha 2
Cold start is now as loud as balls.
Cold start is for heating the cats up faster and can be tuned out, hopefully soon.
Went for a hour drive to cook off the heat wrap.
I might need a resonator in the front pipe, maybe, maybe not.
Stone guard thingie will go back on after I have heat cycled it a few times and re-torqued it all up.
Sounds hektik, LOL
27 minutes ago, r32-25t said:
Does it sound like a rexy bro?
Like a noisy one mate, like a noisy one.
Honestly, I really like it, it's just verging on being a bit too loud. Maybe get some unwanted attention type of loud.
I'm going to head into the local exhaust shop and see what they can do, a big arse resonator, louvered not perforated, in the front pipe might knock the tone/noise down enough to make me happy.
A 12" louvered hotdog knocked a heap of noise out of my MX5, I'm hoping it does the same for the 86.
  • Like 1
Now with added quietness, with the added benifit of the legalities....
Cold start is still louder then I really like, but, meh.
Normal running it is as loud as my old MX5, but deeper, and not tinny, plus no drone.
Chopped a turbo Nissan coming back, shallow victory though, it was a SSS.
  • Like 1
3 hours ago, Dose Pipe Sutututu said:
Line you up in the missus' fully taboulli Tiggy
SAU should do another drag day at WSID.
I went to one years ago with my boat (R33 GTST) and chopped everything, excellent day it was.
I would do another in the 86 for the LOLS alone, chopping some other daily drivers would be a bonus.
I'll buy the donuts.
I'll bring both cars, R33 will blow a gearbox then the Tiggy probably blow the haldex, DSG, motor, entire Canbus network will die and the car will light up 1500 error codes (thank fk it's under warranty)
  • Haha 2
Cold start was still to loud
So, now, my current exhaust is a Tomei UEL header, Ultrex 2.5" overpipe, OEM front pipe back.
Going to the smaller pipe isn't a worry as calculations say that 2 1/4" will flow more than enough NA.
And the OEM front pipe will flow the power its making without much of a issue and will save the kittens and frogs for future generations, which is a bonus.
In all honesty I wish I just did the header and overpipe to start with.
Or, stayed with the decat OEM header, 2 5" catless overpipe and 2.5" cat back, the only issue with that is the trail of dead kittens and frogs in my wake.
Like all things it was a lesson, albeit a slightly costly one.
Dooh.
  • 3 weeks later...
Had a play.
Punched out cat in front pipe.
Tomei UEL header showed no gains over the punched out OEM header.
Hell, the punched out OEM cats with the 2.25" OEM stuff showed typical performance to the Tomei UEL with 2.5" catless exhaust.
There is only so much NA powers you can wring from a 2.0 ltr boxer POS.
I will be reinstalling the punched out header and selling the Tomei.
Making more noise for no extra performance is pointless.
Yes I'm getting old...
I'm keeping this little puppy though, but, I have a itch that needs to be scatched.
Some cheap old POS might end up in the yard, the plant yard to be specific....at work.......hidden......from "her"
  • Haha 2
Until you start spending more time at "work"
12 minutes ago, mlr said:
Had a play.
Buy something cheap, like an 80 series cruiser. And shove a Barra turbo in it.
From memory get Barra after June 2006, and it'll happily make 500kw.
So then wind the boost in, injectors, FMIC, and go rip skids.
Even better run the ZF6 gearbox and turn the cruiser RWD just for the drag racing Lols.
I reckon you can easily get a 80 series into the low 12s in that combo.
    • Yeah the issue here is that we have a lot of topics, unless we matched on the exact word & phrase we'd get a million topics and the one you want will not likely be in the top 20 or so.
    • Yeah great idea, I have already added R32 Wiring Diagram but we can add as many as we want. 100% ! This has been something I've wanted to do for a while. I thought we could have a way for people to 'suggest' a link be added to the library when they come across something good.  We could kick this along by allowing members (maybe a subset) to tag threads they find to allow us to more easily find/locate/use good content, ie a tag 'for-library' which can then be added to the library and maybe have the tags reviewed and updated to better match the content. This would make it easier then to find the content when not using the library. We can also create pages that have lists of content with specific tags. That would allow us to add a tag and then have it automatically added to a page. We could have a page just for the 'for-library' content that we could then moderate and put wherever.  This excites me, the lack of structure with the amount of content is a little overwhelming.
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
