2 hours ago, Dose Pipe Sutututu said:
Hey relaks brah, my engine hasn't gone bang yet, however the motivation has.
You don't really have a lot more to do, do you
Just fire that puppy up and go for a cruise in the mountains or something
The sound of a RB, on boost, reverberating off walls should bring your boys back to the yard, if that doesn't stir the loins then all hope is lost.
Might do a track day next month, let's see if it goes bang then lol.
Because nothing breeds motivation more than breaking your car at the track.
For my sake, start slow
Or, go balls to the wall and post video
I has Pssshh for the LOLS
Only opened a bit currently so only minor LOLS, I tried it everywhere from 100% which brought all the bangs to the exhaust and PSSSHHH to the extreme, right down to closed with nil psshh's
Spring is wound down pretty tight, so only really vents at max boostage, under that its very minor dosage
LOLS are pretty good
  • Like 1
Still not broken
Fuel pump, injectors, Flexfuel and clutch
  • Like 3
  • 3 weeks later...
Contemplating a catback or axle back.
Car sounds stock, except for turbo spooling and tyres slipping.
Conundrums:
1. Pre fab - Invidia? N2? R400?Cold start noise?
2. Shop made - pretty much design what I want with the sound I want.
1. Pro: Would be cheap and I get to install, Con: get what I get given sound/drone wise
2. Con: Would be a bit more expensive vs the massed produced item, Pro: able to test what it sounds during the build, Con: I don't really get to install.
2. Found this axle back pic on the nets, will need to speak to my local exhaust shop, Pro: stock rear pipe and resonator, stock exhaust tips, Con: Cost???, not really any other cons that are blinding obvious.
Disclaimer: this is not a performance modification, pipe work can still be the same as now, just need to do something about the mufflers, I'm after just a little more sound.
I keep leaning towards shop built....like the pic
Hmmmmm
29 minutes ago, Dose Pipe Sutututu said:
External gate, I can supply Turbosmart gate
LOL, yeah nah
I had a "screamer" pipe on my 33, for about 3 days, till it got plumbed back in, it sounded like arse.
1 hour ago, Ben C34 said:
Turbos car to make it quieter, Nek minit..
Yeap, I'm a idiot.....
I swear to jebus I'm one of rhe stupidest old hoons on rhe planet.
I blame all the pot I smoked as a teenager.
Becauseconsumer
Plus I haven't been under the car for ages
1x KDT926 Whiteline Front Gearbox - Mount Bushing (BRZ/86) $35.37 $35.37
1x TS-FRS-Rear Torque Solution Rear Shifter Bushing: Toyota 86 $37.36 $37.36
1 hour ago, mlr said:
I'm fairly free this weekend
Go with @PLYNX this wekeend is mental for me :(
Tomorrow cake delivery (missus side hustle), then accountant, then planning out our bathroom reno with the builder, then buy shit, then going to Hans Zimmer symphony (because all Skyline owners are sophisticated LOLOLOL)
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
