1 hour ago, Dose Pipe Sutututu said:
would be more sleeperere with a 2JZ and Samsonas
Can you spot me, I'll buy you a beer.
Only lets not do 2J as I could never register it, a camed up LS on the other hand is achievable, costly though, but with you paying I'm not to fussed on the estimated $60+k it would cost.
Cheers
I'll keep an eye out for a brown paper bag full of cash dropped on my door step.
  • Like 1
Boost gauge, fully shizzle dizzle, plus $20 3d printed guage holder thing from local guy.
Nothing flash, cheapest gauge I could find really, higher reading than what I really wanted, I tried to find a cheap 15 psi (boost is 8psi) but none were found in the 2 minutes I looked for one, meh.
Awaiting some "add a circuit's" from fleabay so I can get the light and dimmer working.
It doesn't look as bad in person, the camera makes it look all f**ked up, but it's not really that bad.
46 minutes ago, Ben C34 said:
Turn the boost up to use more of the gauge. Problem solved
The rods on these things are make from plasticine apparently.
Pistons and rods are the obvious next big spend.
Then a gearbox solution, it's basically a S15 gearbox and they like to chew.
Not for a while though, I hope, knock on wood, fingers crossed etc. etc. etc.
I believe Yul is pointing at Toyota 86 engine and gearbox parts on the ground.
  • Like 1
May buy some injectors
"Apparently" there is another 30 safe killerwasps available running 98 but I need injectors.
Hmmm, I may have found a Xmas present from me to the car.
I was thinking of upgrading the speakers for Xmas, meh, decisions decisions.......
I was in that situation and I upgraded the speakers.
Reason: Music on in car 100% of time spent in car. In traffic, parked at lights, cruising around, while car warming up, middle of thunderstorm.
Extra injector requirement is something like 0.01% of time spent in car.
  • Sad 1
Sad but true
But really, how much clearer can 92.9 ABC Classic radio be?
But then common sense rarely gets factored into my plans, or even cross my mind really, ....but when it does I try to just force it down with all of the other bad things, to fester and boil, until it expodes in a tyrade of utter self righteousness.
On 05/12/2019 at 10:16 PM, Dose Pipe Sutututu said:
Lol well I did a Christmas too.
On the wrong car ?
Got the delete fitted yet?
Gonna block the bypass for some Sutututu?
Or
Hektiks
  • Haha 1
5 hours ago, Dose Pipe Sutututu said:
Not a BOV ulleh
Yeah it's a turbo muffler delete for the Vag, isn't it???
I was just asking if your gonna play with other bibs and bobs.
Make the Tig all turbo noisy and obnoxious, like I like, yeah, you know what I like......
So is it fitted yet?
If so picks and thoughts......
38 minutes ago, Dose Pipe Sutututu said:
Not yet, been bed bound after my op, then had to go back to hospital after my body rejected the antibiotics (too strong).
  • 4 weeks later...
I lost another wheel nut a while ago, decided to get a new set, I already had 2 different styles
Went full consumer, Project Mu floating, made from Chromium-molybdenium steel, guaranteed extra 10hp at the wheel brace.
Did get an epic deal from the boys at Just Jap.
OCD go on ?
    • You have (externally anyway) a lot of patience!  At the very least your patience has rewarded you financially even if you decided you were over it!! I only just read your first experience of seeing the car, that would have been amazing!  Well documented too! It must be exciting knowing there's only 10 months left until you can get it on a boat and on it's way!!!???
    • Yeah, that's when. I guess you could say I'm as patient as I am foolish(or just a masochist?🤔). I've strongly considered throwing in the towel and calling it all quits many times, and have almost done so. It's a first-world problem for sure, but I've had a pretty rough go of it, as well as other factors; hoping something good comes of all this; it has to. It definitely is half the price of the ATS and performs great, but I'd like to try something different for once. I've sampled the ATS in a friend's 32 and it's solid👍
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
