1 hour ago, Dose Pipe Sutututu said:
would be more sleeperere with a 2JZ and Samsonas
Can you spot me, I'll buy you a beer.
Only lets not do 2J as I could never register it, a camed up LS on the other hand is achievable, costly though, but with you paying I'm not to fussed on the estimated $60+k it would cost.
Cheers
I'll keep an eye out for a brown paper bag full of cash dropped on my door step.
  • Like 1
Boost gauge, fully shizzle dizzle, plus $20 3d printed guage holder thing from local guy.
Nothing flash, cheapest gauge I could find really, higher reading than what I really wanted, I tried to find a cheap 15 psi (boost is 8psi) but none were found in the 2 minutes I looked for one, meh.
Awaiting some "add a circuit's" from fleabay so I can get the light and dimmer working.
It doesn't look as bad in person, the camera makes it look all f**ked up, but it's not really that bad.
46 minutes ago, Ben C34 said:
Turn the boost up to use more of the gauge. Problem solved
The rods on these things are make from plasticine apparently.
Pistons and rods are the obvious next big spend.
Then a gearbox solution, it's basically a S15 gearbox and they like to chew.
Not for a while though, I hope, knock on wood, fingers crossed etc. etc. etc.
I believe Yul is pointing at Toyota 86 engine and gearbox parts on the ground.
  • Like 1
May buy some injectors
"Apparently" there is another 30 safe killerwasps available running 98 but I need injectors.
Hmmm, I may have found a Xmas present from me to the car.
I was thinking of upgrading the speakers for Xmas, meh, decisions decisions.......
I was in that situation and I upgraded the speakers.
Reason: Music on in car 100% of time spent in car. In traffic, parked at lights, cruising around, while car warming up, middle of thunderstorm.
Extra injector requirement is something like 0.01% of time spent in car.
  • Sad 1
Sad but true
But really, how much clearer can 92.9 ABC Classic radio be?
But then common sense rarely gets factored into my plans, or even cross my mind really, ....but when it does I try to just force it down with all of the other bad things, to fester and boil, until it expodes in a tyrade of utter self righteousness.
On 05/12/2019 at 10:16 PM, Dose Pipe Sutututu said:
Lol well I did a Christmas too.
On the wrong car ?
Got the delete fitted yet?
Gonna block the bypass for some Sutututu?
Or
Hektiks
  • Haha 1
5 hours ago, Dose Pipe Sutututu said:
Not a BOV ulleh
Yeah it's a turbo muffler delete for the Vag, isn't it???
I was just asking if your gonna play with other bibs and bobs.
Make the Tig all turbo noisy and obnoxious, like I like, yeah, you know what I like......
So is it fitted yet?
If so picks and thoughts......
38 minutes ago, Dose Pipe Sutututu said:
Not yet, been bed bound after my op, then had to go back to hospital after my body rejected the antibiotics (too strong).
  • 4 weeks later...
I lost another wheel nut a while ago, decided to get a new set, I already had 2 different styles
Went full consumer, Project Mu floating, made from Chromium-molybdenium steel, guaranteed extra 10hp at the wheel brace.
Did get an epic deal from the boys at Just Jap.
OCD go on ?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
