23 hours ago, mlr said:
Ok.......LOL.......Apparently a turbo is a excellent way to muffle down some cold start noise.
Can we start a sweeps for how long before current exhaust is replaced with full 3" decat, straight piped one to get more out of the turbo setup?
I'm pretty sure the 2.5" decated system will be fine for 190ish kwatw.
Even with the aded weight of the turbo I'll still be under 1300kg, which isn't bad for a daily with all the modern conveniences.
In other news, I WANT MY BOOST NOW, I'm so f**king impatient, waiting a month for it to happen is going to suck.
  • Like 1
19 minutes ago, Steve85 said:
Good choice. I've got RE003s on my daily's. Probably the best tire (for the money) that I've ever driven on.
I do prefer RS4's (talk about value for money), BUT, whilst RS4's are brilliant in the dry, they are pretty average in the wet.
Compromises were made because street car.
There was a special on at JAX, 4 tyres and a wheel alignment for $550, bargain.
  • Like 1
2 hours ago, Victory said:
I am sorry but I still cannot believe that an 86 can turn a 235 tyre........
QFT
LOL
Seriously though, the little girl has surprised a few people.
It ain't no rocketship, but, tuned NA it puts out more than a stock turbo S15, it's currently 145kwatw, add some PSI and it will be around 190-200.
Plus at 1250kg, the power to weight ain't really horrible either.
Opinions may vary
For what its worth, I recently took a little orange Renault Megane 225 to Winton with a tune and similar rubber. I wish I had more tyre and it has the same modest power to weight. Plenty to have fun with. 80+ hot laps in a day also is a breath of fresh air relative to most outings with a broken Nissan. ?
I say continue having fun.
That's the plan
Until it breaks...?
Street alignment all dialed in
Front: -1.5°, 0 toe
Rear: -1.0°, 0 toe
Will be going for a squirt up the pass for a pie on Saturday, I'll then take the long way home via Jamberoo, also with a detour past the lighthouse in the Gong, and by lighthouse I mean the icecream van in the carpark near the lighthouse.
In all honesty though, the set up is more about tyre life and daily driving with illusions of performance, more so than actual performance.
19 days to go till tututututu, which, is the main reason why I'm getting a turbo anyway.......
51 minutes ago, Dose Pipe Sutututu said:
LOL you what?
Knew you couldn't keep it NA.. NA cars are for homos.
LOL, I did inform the boys at Pulse that the more annoying turbo noises the car makes the better.
I'm not sure that 8 psi is actually enough boost to make annoying noises though.
We shall see on Friday I suppose.
f**k I hate waiting.
In other news: if work sends me away before this weekend I'm gonna have a melt down.
Work has a nasty habit of sending me away for months at a time, just when I am getting something done.
It's like they are waiting for me to drop off my car.
Me: "I just dropped my car at the shop"
Work: "Cool, pack your bags, you leave tomorrow"
    • Grind them off, drill them out. Repair any rust on the other side. Start again from scratch.
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
