1. Fresh built short block RB30 stroker 3.4L 94mm spool crank, Spool I beam rods, Custom CP pistons 87mm (40 thou over) all parts now still have boxes block currently at Abbotts Engineering Gold Coast. $6000
2. Haltech platinum pro r33 rb25 $1250
3. ID Injectors with fuel rail and Sard FPR and fuel pressure gauge. $800
4. 3 x Bosch 044 fuel pumps 2 new 1 used $150 new and $100 used
5. 2 x Walbro in tank fuel pumps 1 new and 1 used. $100 new and $80 used
6. 70L aluminium drop tank fuel cell $150
7. Custom made aluminum radiator shroud with 2 x thermo fans + aluminum radiator $400
8. R33 ARE oil cooler fits between headlights with steel braided hoses. $500
9. Massive intercooler new in box $300 can get size upon request
10. Garrett GT3582R used 1000kms max $1000
11. Garrett massive truck turbo unknown specs can get specs upon request.
12. Top mount exhaust manifold with 38mm external wastegate and screamer pipe. $250
13. HKS Super dragger high flowed $250
14. HKS oil filter with relocator kit $200
15. HKS BOV SSQV $75
16. Huge yellow top Optima 990 CCA dry cell battery $225
17. Eboost2 with wiring and mount near new condition $450
18. Autometer carbon fiber gauges ( air-fuel ratio, water temp, oil temp, boost and fuel pressure) $75 each or $300 for the lot.
HEAPS MORE PARTS INCLUDING SHELL, INTERIOR, AFTERMARKET AND OEM. HEAPS OF CARBON FIBRE PARTS.
CALL OR MSG ME FOR DETAILS AND PICTURES. LOCATED GOLD COAST, QLD
0423016792
20180704_111601.jpg20180704_111639.jpg20180704_111856.jpg20180704_112432.jpg20180704_112425.jpg20180704_112026.jpgIMG_1242.JPGIMG_1243.JPGIMG_1248.JPGIMG_1249.JPG
  • 1 year later...
Hi mate
how much for the carbon fibre gearstick cover with ash tray(don’t know what to call the piece)
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
