1. Fresh built short block RB30 stroker 3.4L 94mm spool crank, Spool I beam rods, Custom CP pistons 87mm (40 thou over) all parts now still have boxes block currently at Abbotts Engineering Gold Coast. $6000
2. Haltech platinum pro r33 rb25 $1250
3. ID Injectors with fuel rail and Sard FPR and fuel pressure gauge. $800
4. 3 x Bosch 044 fuel pumps 2 new 1 used $150 new and $100 used
5. 2 x Walbro in tank fuel pumps 1 new and 1 used. $100 new and $80 used
6. 70L aluminium drop tank fuel cell $150
7. Custom made aluminum radiator shroud with 2 x thermo fans + aluminum radiator $400
8. R33 ARE oil cooler fits between headlights with steel braided hoses. $500
9. Massive intercooler new in box $300 can get size upon request
10. Garrett GT3582R used 1000kms max $1000
11. Garrett massive truck turbo unknown specs can get specs upon request.
12. Top mount exhaust manifold with 38mm external wastegate and screamer pipe. $250
13. HKS Super dragger high flowed $250
14. HKS oil filter with relocator kit $200
15. HKS BOV SSQV $75
16. Huge yellow top Optima 990 CCA dry cell battery $225
17. Eboost2 with wiring and mount near new condition $450
18. Autometer carbon fiber gauges ( air-fuel ratio, water temp, oil temp, boost and fuel pressure) $75 each or $300 for the lot.
HEAPS MORE PARTS INCLUDING SHELL, INTERIOR, AFTERMARKET AND OEM. HEAPS OF CARBON FIBRE PARTS.
CALL OR MSG ME FOR DETAILS AND PICTURES. LOCATED GOLD COAST, QLD
0423016792
20180704_111601.jpg20180704_111639.jpg20180704_111856.jpg20180704_112432.jpg20180704_112425.jpg20180704_112026.jpgIMG_1242.JPGIMG_1243.JPGIMG_1248.JPGIMG_1249.JPG
  • 1 year later...
Hi mate
how much for the carbon fibre gearstick cover with ash tray(don’t know what to call the piece)
    • I've replaced the front brakes of my NA to 324 brembos and 350z calipers: i'm going for 225/40-18 up front and 245/35-18 in the back. I have Rays 7.5*19 ET35(225/35) in the front with 5mm spacers otherwise the calipers "lock up/ won't rotate". When i use the calculator i come up with 8*18 ET30 for 225/40...... but not sure i get problems with the calipers. Anyone riding around with 18 inch. that can confirm "that it'll fit"? In the back it's 7.5*9 ET30 (245/30) with the 5mm spacers, but there is no problem with the standard small brakes, so i want to take 8.5*18 ET25 (245/35).
    • Lol.. but then.. always come back to a JDM..
    • Glad to hear. If possible, get your tuner to check air's to make sure everything is still where it should be.
    • The problem with FB/Insta/Reddit etc comments relating to cars is simple. You get to ask a question once, and get one round of replies. For things that can actually be answered in a few lines of text, once, it's fine. After 6 hours, your original question is lost to the void. There are no follow ups, additional questions, anything. No project car is ever such a simple list of questions to ask. You need discussion.
    • Welcome.  Here's what I have noticed about forum vs FB..... FB; seems to be wallet racing, and the same few questions asked over and over. There *may* be some groups that are closer knit, but most have changed for the worse. SAU; unfortunately, no longer in its glory days. But....genuine people with similar interests. Not all about how much you spent and saying you dont have enough power. Sooooooo much knowledge available. Have personally seen people post up about literally topics I made myself, asking on FB like no one has done it before. Most has been done, and most of that is here.   If you ever feel like just general chatting theres the wasteland.  Other interests are also generally covered in other areas of the forum. Hope you enjoy hanging around. We would love to have you.   P.s. nice 32 😀
