Just wanted to share with everyone some concrete information regarding replacing boot struts on R33 skyline, specifically the GTR but I am sure the information will be transferable. The reason I am posting is that there wasn't much information regarding pressures & the ability to remove the strut from the bracket (requiring drilling).
What I did ended up costing me $110.
Below is a picture I pulled from another thread, this is the part of the strut that is hard to remove. Very hard, but not impossible. What we did was use my 10mm spanner and wedge it in between the ball and the strut, then slowly work the it off. It looks like it's going to snap the strut and it ends up destroying it, but that's ok because new ones are cheap.
This is what mine looked like in the end.
_l_YlkhMrhBQ8EuTW0y2zCoronteQxKCJER7sheMowcDwPIacsgt8UsL1x21IK-aTNXtvJXg3_kDwKUO7ncCs5DhF97OgP03zCT2utJVgpasCM6swm6c6yBZghppOjRhrCDRNymusekRCAFCSLVeDDiJm-IyBLP34tFaLLj8iCNpO2l6-UBwXrdBHA8BrnRC2PnUvzFoIlPfql9mXz8kCw2L9ytvHw6U1scTkSBwqeMqsIX3wNksn_sPAbpZy7Kvlh3mOQGX7KphM2zUYUYY7fQyb_6DonTPI7HHveh-rqFTAxWNHIakGcNYvps9VAVQj_mvLAeoAlYLLJc-G9y9JH0t6EtBHhm5yN24o8_VHlDPboaZSpn4JoPdTUqAsb1Bh6kMrn--BwO5A_lftYEt7veVc8Mlg_eRZDr1nmb-pRaFW7WM8t08Ovg1xyN9jqbzhrRYS7wM9y4AxFwLHATXOaDlynuPHkZcUgY0ibAGwO6JeF_uLZs7dOxy4wcKj_m3rfQvjU6XJDkOfYiD5s24OyPnXqpZlMiQAxzc1wHM3VbEVKYgpPWqY3Ai_QBEcx5qndaGyljSAFyMJYY8KCQYhf5Icq7Vf4hdq6ORlGA=w731-h974-noMO_Ysbf9qqSSN3mh_W5cj--ZVZTDnQEdrg71b3qAL6ClwNPe2BAzRm9ffXwQtLNShfvVSrGZb1awzrTs-3wsiEDqajZLPoN-XH-oo3yrhDvt5S_iPPMs7CTedRr8Y9WVnNO4f4jH3znvJrerLZKaR1GZUm0gc0JunMDdDGBD_5Lga0DDMfHnarSUZq363IDwK97xkihWKBzrJRQAwiFYQw5j1Z9Dnv164W7OSwGE4XGxZ2eHIXysSShGk4IjHd_zD9SavOpyaH66YFmaVk38ecHVh0F1n5WLR9v8cqwuRQWMUZFyBWKd4hFCiprRS1wRgHjT9Iq1NS14jwjcKH2J9ydIEwV-D0wFsaZ5iPU1TVRZbW64atB04SPiQLer1iaCjN8IQuaboBUJBroqU-fMS23BF47Nh-odqGUvevbRwZJlZq-y8SrFnzt4yEWXv_Gd9q3ynKsZF2BcZsbcgSnhLdmijitWj445px4bXxpp9G_r_3lYpT3DMNRp0q12ksFoBKJ-o1_dLONJpkt8z3TBNpHHgJpGpvqu1omhtPLvdPN8GYOocaBcbO6StAmCCNv8PSKanLGhsXMwgLBHVr5axmsFFRB284OaLppLBXg=w731-h974-no
We ended up putting 100nm of pressure in each cyl. It holds the boot fine with a genuine GTR spoiler. If I had to do it again, I would put 150nm in each to see if it holds any better, BUT that 100 works just fine.
Any questions please shoot them through.
Edited by sleptema
  • Like 1
https://www.sau.com.au/forums/topic/474449-r33-gtr-gas-boot-struts/
What's 100nm in real pressure units?  You have given units of torque.  Pressure is measured in Pascals or multiples thereof (like kPa, MPa, etc) or in psi for knuckle dragging 'Muricans.  Or in N/mm2 (equivalent to MPa) or in bullshit units involving the heights of columns of fluid such as water or mercury.
Yeah sorry guys, I was thinking about that this morning and realised how stupid I must sound aha. The guy who did my struts didn't correct me, I believe it would be newtons.
EDIT: Re-uploading pictures of finished product.
Edited by sleptema
  • 4 weeks later...
  • 4 weeks later...
Hi all,
I am also keen to know where I can buy these as I have been looking and found nothing except a few used struts on eBay.
Any help would be appreciated...Every time I need to use my boot at the moment I feel like I have my head in a guillotine!!
On 7/31/2018 at 12:02 PM, Ty1 said:
Where abouts did you get this done? And these are new struts yeah? or did you end up managing to reuse the factory ones?
I used a generic strut specialist. Old ones needed to be thrown out as there was no way they could be re-used. He just used the brackets from the OEM ones and adapted them to fit on the new struts.
I believe he just measured the extents of the struts and ordered accordingly, and put above mentioned pressure into them.
  • Like 1
  • 8 months later...
Hello
my Gas Strut were weak so I want to replace them.
This Topic pointed me in the right direction, thanks !
You can chosse this Model from Mercedes Part No.: 2218800329
It s from the W221 S Class Hood strut.
You can find them for around 14$ on Aliexpress. They are a little bit too strong so I recommend to buy some used ones.
I only replaced one and the Hod stays in any angle.
I recommend to tap an M6 in the Bracket and add a nut to secure the strut.
They are a 14mm  to short, so the Trunk opens 12 cm less. Adding a spacer will fix this
I also replaced the rubber bumper . They are from Aliexpress also.IMG_2323.thumb.JPG.afe41b4eae5716055d1b1a494c668e28.JPGIMG_2326.thumb.JPG.1e7e979e952d3c797bb5eeadcbb3328a.JPGIMG_2328.thumb.JPG.0afff9f21876085c3da8d913c770010d.JPG
Edited by Fastlane
  • Like 1
  • 3 weeks later...
So I did some research, cause the Mercedes Strut were to strong
The original USED Struts have 30 kg while pushing and approx.20-25kg while holding.
The new ones should be around 35kg-40kg
And i Find the perfect one again on Aliexpress
search for:IMG_2392.thumb.JPG.21d8a83675800d67e8a9bd41aebdf543.JPG 320Mm 400N Flap Spring Flap Fitting Gas Spring !
they match perfectly.
The Trunk lid will hold until 15cm before reaching the lock.
  • 2 months later...
  • 3 weeks later...
On 13/08/2019 at 1:21 PM, rych said:
I hate to necro this but when you use a 10mm spaner to wedge the strut out did you had to drill a hole to make new strut fit?
Nah, the strut guy just got a fitting on the new strut that fit over the 10mm ball joint.
  • 1 year later...
On 20/05/2019 at 8:47 PM, Fastlane said:And i Find the perfect one again on Aliexpress
Hopefully this is still correct years later because I’ve just purchased some. Cheers mate
  • 3 months later...
14 hours ago, joshuaho96 said:
I need a replacement for the trunk gas strut
https://www.ebay.com.au/itm/AUTOPA-Gas-Bonnet-Strut-for-Mercedes-W221-C216-S350-S450-S500-S63-A2218800329/254807343124?hash=item3b53b38014:g:5fMAAOSwBYteZbCj&frcectupt=true
here's the link on ebay for the struts, in stock in Sydney.
If you need any strange brackets or ends. Here's the link to a strange brackets or ends seller also local.
https://www.gasstrutaustralia.com.au/
I'm in the US, my concern is that the gas strut is too strong. The Alibaba generic one is said to be more appropriate, so I'm thinking of trying one of those first.
On 23/01/2021 at 3:09 PM, IM-32-FK said:
Don’t get replacement ones, you can get the OEM ones regassed. There’s a couple of places in Sydney that I know who do it.
Only if the seals are good. If they're not, which they probably aren't, they're a throw away. Just retain the top boot lid mounts to adapt to new ones.
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
