I posted this car before but retracted it when I thought it had a problem. It turned out to be a dud spark plug and all is well again so it's back up for sale.
Here it is again:
Factory Black 1990 GTSt Type M Rego til Dec 04
This is not a show car but a standard looking car with all the good gear on it.
THIS IS A PERSONAL IMPORT VEHICLE SO ADR COMPLIANCE WAS NOT REQUIRED AND MODS ARE LEGAL ( so long as they are deemed roadworthy which these are ).
The Go Bits. :wassup:
Engine rebuilt late last year with Arias Forgies, balanced bottom end, medium level head work including match porting heads to manifolds. Chemical Cleaning and repainting was done.
Other features are:
- High Energy 9L capacity sump with trap doors etc.
- New Oil and Water pumps, mounts and tensioners etc.
- Earls Sandwich Plate and Oil Cooler
- Power Enterprise 550cc Injectors
- Splitfire HEI Coil Packs
- Ducted Apexi Pod Filter
- HKS GT2535 Turbo ( In excellent condition ).
- Split Ceramicoated Dump Pipe into 3" Apexi S/Steel Exhaust
- GReddy V-SPL Front Mount Intercooler
- OS Giken Twin Plate Clutch
- Cusco Catch Can
- Cusco Strut Tower Brace
- Nismo Fuel Pressure Regulator
- Chipped Stock ECU
- GT-R Fuel Pump
The Drive Bits. :burnout:
- Standard G/box
- Rebuilt Tailshaft
- ATS 1.5 Way LSD
- Dummy Rear Steering Rack
- C's Short Shifter ( with heavy G/Knob )
- Custom Valved Bilstien coil-overs with height adjustable King Springs
- Custom Sway Bars
- Cusco Front Upper Ball Bearing Links
- Caster Kit ( Brand un-known )
- Rear Cradle Pineapples
- A Tech Monoforged alloys (F) 17x8" & ® 17x9" with Falken 235/45's and 255/40's
The Stop Bits. :confused:
- EBC Front Discs and Pads with Synthetic Brake Fluid
- Cusco Brake Master Cylinder Brace
- Nismo Coated Braided Brake Lines
The Other Bits. :uhh:
- Nismo 260kph Speedo
- Pivot Shift Light
- Blitz Racing Boost Gauge
- Sony Explode Head Unit
- Kenwood Amp
- Kenwood Front Splits
- Pioneer Rears
- 10" Boxed Sub
- Tinted Windows
- GT Gearlock
- Other spare bits and pieces included
The Price. :(
Now $19,900 FIRM ( Priced to sell ).
No time wasters or joy riders please.
NOTE: I don't have a digi camera but if there's genuine interest I'll try to organise
something.
https://www.sau.com.au/forums/topic/47445-modified-r32-gtst/
Forgot to mention, I would also consider a trade and cash adjustment with either ot the following if in extremely good and stock condition.
- Manual R32 GTS 2 door with RB25DE ( NON TURBO )
or
- Manual S13 Silvia with SR20DE ( NON TURBO )
As you may gather by this, I have a small problem with my right foot and am selling my car and moving into something slower to try to keep my licence. :uh-huh:
https://www.sau.com.au/forums/topic/47445-modified-r32-gtst/#findComment-960276
To all who have shown interest, thanks, and I now have a semi-dodgy-digi camera ( and am learning how to use "properly" ) so by Monday I should have some pics which I'll try to post here as opposed to sending them to all of you individually.
If I can't do this, I WILL send them out to each of you.
https://www.sau.com.au/forums/topic/47445-modified-r32-gtst/#findComment-970159
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
