Hey all. So I'm having issues with my R32 GTST RB20DET. Basically, after driving it for 5-10 minutes, it starts to steam and white smoke comes from under the hood. It seems to be originating from the area around the #5 fuel injector. It smells like coolant and the day before, it got so bad that my coolant was completely drained. I replaced a couple of faulty vacuum hoses, but it still steams out coolant. My car isn't overheating either. The oil doesn't look creamy and there's no white smoke coming from the exhaust, so there's no clear cut problem. The ac and heat also work just fine. Any help would be greatly appreciated
https://www.sau.com.au/forums/topic/474455-white-smoke-from-hood/
7 hours ago, Jordy32 said:
Ok, sounds like there's no coolant leak glad you can confirm that.
It does however sound like coolant is exiting the cooling system and is evaporating which is creating the steam so look for that point of exit.
It looks to be exiting out of the block, under all the vacuum hoses up top, around the #5 injector. I just bought an intake manifold gasket just to be safe. I have limited time and resources, so hopefully it does the trick
