What does the eFlexFuel box do?  What is its purpose?  Reason I ask is, it wouldn't be a necessary item to run e85 via a Nistuned factory ECU.  If it is some sort of interceptor to artificially boost injector pulse widths to make them work on e85, then I would suggest not using is, or the kit.  Just do the job properly.  New injectors, big pump, Nistuned ECU.
https://www.sau.com.au/forums/topic/474465-flexfuel-kit/#findComment-7880603
Those flex fuel kits just pump like 40% more fuel in and that's it.. no changes to ignition timing.
Get a Nistune and if you wish, get a ECA by Zeitronix and feed the 0-5V output into Nistune equipped stock ECU.
https://www.sau.com.au/forums/topic/474465-flexfuel-kit/#findComment-7880674
1 hour ago, admS15 said:
Sorry to spoil the party guys but m35's cant be nistuned unless there's been new developments I haven't heard about.
I am aware of this. When I asked nistune
57 minutes ago, GTSBoy said:
Oh, in that case, just throw a match in it and claim it on insurance.
Why would I burn a good car???‍♂️
https://www.sau.com.au/forums/topic/474465-flexfuel-kit/#findComment-7880686
