So I am making this post as I've searched the forums, and the posts I could find aren't fitting my personal situation.
I've already got all the supporting mods for my turbo upgrade, Front facing Plenum, 6boost turbo/ exhaust manifold with T3 fitting, 1000cc injectors, walbro 460 fuel pump, all the gaskets you could dream for, electric boost controller (Already in), Blitz Nur Spec R exhaust, and a front mount intercooler.
I've tried making another post elsewhere on these forums reguarding a turbo upgrade, and said post got closed as apparently it's totally fine for people to insult a build, but it's not ok for people to make a new post on a forums, asking for help to suit their situation. My build is unique to 99% of builds on here, I am getting all my modifications engineered and permitted accordingly. I'll be installing all the mods myself, making sure they all apply to the legal standards (Plumbing back to exhaust, emissions) and then I'll be paying an engineer to get it certified.
For the turbo upgrade, I am wanting a minimum of 350HP, but I'm looking at around 400- 450HP. The turbo that I require will have to be with a T3 housing (I know garrett give the option for a lot of their turbos to suit multiple fittings). I have no experience with turbos at all, as my skyline is the first performance car I've owned. If someone could give some serious suggestions, someone who knows what they're talking about when it comes to cars, as to what Turbo is good, and what to avoid, that would be amazing.
Also, forgot to mention, but I want this turbo for street performance, and a bit of track time, possibly drifting every now and then on track, so I'm not 100%, but I think that would mean I need a responsive turbo with high boost at low RPM? Cheers!
https://www.sau.com.au/forums/topic/474505-need-advice-upgrading-r34-gtt-turbo/
There is nothing especially unique about your build. While it is true that every car is slightly different  there are literally hundreds  of examples for you to choose from in this thread
which is why your other thread was closed.
We can build u an ATR45SAT ball bearing turbo. that is good enough to make over 400rwkws on E85 fuel or around 360rwkws on pump 98. super responsive, 20psi by 3700RPM. You can find results of it on dyno reading section. Add me on your FB I'm happy to provide you with more information or combination of other turbochargers as well as general mods required getting up to your performance goal.
What's your budget?
These turbos below are all good and listed in order of cost (my personal preference):
  • Hypergear ATR45SAT CBB
  • Garrett GTX3582R Gen 1 w 1.01 divided rear housing (need a new manifold to benefit the twin scroll)
  • Garrett GTX3582R Gen 2 w 1.01 divided rear housing (need a new manifold to benefit the twin scroll)
  • Borg Warner EFR8374 (but you'll need to get a new manifold, wrong flange)
My budget would be about 2.5k at this current time. That HG turbo looks amazing, but the only thing that throws me off is the internal gate + minimum boost of 20PSI. This car is my daily, I want to be able to alter my boost controller, and run a chillaxed 10-12PSI for everyday cruising, and be able to up it to 20- 25ish PSI if I want to. I've heard that the whole twin scroll setups are good, although they offer high boost at low RPM, and then low boost at high RPM. I'm after something in the middle. Also, if anyone is able to help me with a very stupid question that I have no idea what the answer is: What do I need to know about the turbine housing fitting size? The whole 0.6 A/R and 1.0 A/R values. What does that mean? And with my engine, what sizing would I need?
Stands for Area/Radius ratio. Simply put it is like gearing - a smaller number will usually spool up more quickly a larger will give more power at the top end...but there are many variables.  As I said before learn from other people - go to the RB25 turbo upgrade thread and see what different turbos do for each car. Unfortunately not everyone lists the A/R of their turbo but there is a lot to learn by reading through the thread . The ideal for you depends not so much on your engine as on your choice of turbo and intended use.
On ‎7‎/‎15‎/‎2018 at 7:55 PM, admS15 said:
Garrett gtx3071 or gtx3076 gen 2. If you want to save some $ have a look at hypergear turbos, they have plenty of options for rb25. There is a thread with hundreds of pages of info in this site.
This...all wrapped up and ready to go!!! Don't overthink it, the Garrett GTX range and/or Hypergear setups are tried and proven and would be ideal for your setup.  And one with > 0.60 to <0.85 would be my pick.
Only single other bit of advice......stick with a reputable trader, don't buy from some 'fly by night' pop up shop that can't help with advice or after sales.  This way you know what your getting, its not some Chinese knock off.
Cheers for the help everyone! I decided to go with the Hypergear ATR45 with ball bearing and 3" dump pipe. Should hopefully achieve close to 450HP at the wheels in a few weeks! Now I've got to organise a new exhaust, book in a tune, and book in an inspection to get it all engineer approved.
Hey @Dose Pipe Sutututu do you actually know what makes the motor go 'bang' after a while? Is it lack of servicing? Lack of checking tension on belts? What actually makes the motor die after a while, and not straight after installing the mods? In your case, what specifically was the sole reason to your motor dying? pistons or something? Because I'm willing to check the main components, timing belt, oil, coolant, hoses, leaks every week to ensure nothing goes wrong. What was it in your case? And even other people's experiences too?
Ringlands on the RB25DET break, on the NEO motor they don't seem to break at the 400kW mark but with enough heat/stress/abuse it will eventually go.
Mind you, mine was driven hard on track days. I would easily rack up about 60 to 80 laps each time I went to Wakefield Park. If my shit box was purely for street and the drag strip then I doubt it would have gone bang.
Ah righto. Well that is interesting. Also FYI everyone, my turbo and plenum arrived today, so tomorrow I start the long, hard process of installing my fmic, ECU, fuel pump, injectors, turbo manifold, dump pipe, plenum and turbo. Will be a lot of fun re- doing the piping for the plenum I hear. Also, I was wondering.. My ECU that I bought had a tune with 1000cc injectors, walbro 460 fuel pump, fmic and bigger turbo. Would it be safe for me to drive the car maybe to a tune place as the mods I just listed are literally what will be in my setup. Or will the engine go bang? I understand the cylinder compression will 100% be different, but will that alone be enough for my car to go bang if I'm driving like a grandma to the tune shop which is about 10km away if that?? Cheers
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
