Hi guys
I've seen a couple of threads on this subject but none that answered my specific question. I've had my 2009 370GT (7 speed auto) sedan for over 3 years and 20,000km now and ever since I bought her I've only ever used 91 petrol (the same as I did for my V35 300GT) because I never did any investigating. I have never had any problems running on 91 - she runs smoothly and perfectly, does 0-100 in 5.5 sec, no pinging, rough running etc, and I can consistently get over 600km on a tank with a motorway, city, cruisy and wheel spinning mix of driving. It was only researching about doing an oil change  myself (and downloading a US Infiniti G37 manual) that I came upon the concerns about using the wrong fuel.
Is it okay to keep on going as is or do I really run the risk of damaging the car?
Cheers
Edited by nzrhysco
https://www.sau.com.au/forums/topic/474524-petrol-type-for-370gt/
It's fine, US petrol is is like dirt water, our minimum octane is like premium over there... In an n/a factory tuned application you won't have any issues. The only benefit (as far as I'm aware) of using 95/98 in an n/a is some additional cleaning additives
Would anyone know what the Japanese V36 are tuned for? 98 RON? Maybe 95 RON?
North America uses AKI while we use RON to measure/advertise octane ratings.
91 RON = 87 AKI
95 RON = 90 AKI
98 RON = 93-94 AKI
https://en.wikipedia.org/wiki/Octane_rating
  • Like 1
Trust the US to use a different rating unit ?
Some wise advice from the Oregon Dept of Agriculture: "Listen to your car’s engine. If it doesn’t knock when you use the recommended octane, then you are using the correct grade of gasoline." ?
Try to get a 80 - 120 time (hold in gear so no gear change if possible).  Run your tank as empty as possible and then after a few fills . with 98 reset your ecu by disconnecting the battery for a few minutes and then repeat the test. I would expect a tiny increase in performance but would in any case stick with 98 where possible for the reason above (high compression engine).
Thank you for your replies, but some of you are missing the point. The book says use 96+, so obviously 98 is ideal, but I have been using 91 for over 3 years with no loss of performance or economy or signs of issues with the engine. She has also been serviced by my local Nissan dealer. Essentially I want to confirm that if my use of 91 was going to cause any problems then it would have shown up by now. Is this correct?
Thanks
You are definitely suffering a loss in performance because the ECU is retarding the timing to prevent knocking. How are you so sure that you're not? The butt-dyno is not an indication.
Also, regular servicing doesn't mean you're preventing the effects of pre-ignition detonation from turning your cylinder bores egg-shaped prematurely. Unless you pull the engine apart, you won't know.
The point is, you know Nissan specify a high octane fuel. So why are you going against their instructions by using such a low octane fuel in the first place?
  • Like 1
My point is that I didn't realise I was using the wrong fuel. The cars done 35000km and Im only doing 6000km per year so I don't care if it reduces the total life of the engine as I'll be selling her before 50,000km. I just wanted to know if any issues or consequences are going to show up in the short- medium term, and based on my own experiences over 3 years, I will say probably not!
You're right about the short-medium term. At worst, perhaps blocked injectors over time because of the lack of reasonable cleaning additives in the fuel.
But now that you know better, hopefully you've made the switch to 98 octane.
So why bother posting? If you want to learn something (you could share with us) do the back to back testing as above.
  • Like 1
Also interested to know what book said 96+ octane...
Personally have run all my imports (including my KV36) on 98 octane, and glad for the cleaning packs that have helped keep the engine and injectors nice and internally clean.. I also do low mileage like you and therefore have less of a concern about fuel prices and consumption and so can enjoy my car.. :-)
  • Like 1
  • 1 month later...
Biodiesel is biofuel. Ethanol blended fuel (E85) would be sort of bio fuel.
But then, petrol is refined oil out of the ground, which used to be tiny creatures hundreds of millions of years ago. So you could say all oil based products are "bio", sort of?
  • Like 1
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
