Hi,
I'm in there process of deleting the factory heat exchanger from a rb26 block. i want to use a greedy/trust oil filter relocation kit.
What i was thinking of doing was, installing a oil pressure relief valve in the block. As the oil pressure relief valve is in the standard heat exchanger.
Installing a rb30 oil filter stud and sitting the greddy/trust (grex) adapter on the block. Then running my lines to my remote oil filter location.
Will oil pressure relief work ? will the grex adapter seal on the block ?
Genuine-Nissan-Oil-Filter-Pressure-Relief-Valve-15241-40F00-Nissan-RB.jpg.6f1ef36f39e8b030fe425a83ef81ae4f.jpgGenuine-Nissan-Oil-Filter-Stud-15213-W040A-Nissan-RB.jpg.63176deb5bb4d54058db17ef4157d66d.jpg37253670_10157611250223047_8495535437081739264_n.thumb.jpg.d6cfc9ca0e720558efc8b287b12c9c27.jpg
any experiences or knowledge will be greatly appreciated.
Thanks.
https://www.sau.com.au/forums/topic/474531-rb26-oil-filter-housingadapter/
Your method would work but say if the centre bolt gets loose you're going to be in a world of trouble.
I did this, seals 100%
JHH Racing oil block, has 2x 10AN outlets, 2x 1/8NPT for gauges and 1x M10 for the OEM oil temperature sensor.
  • Like 1
Im putting a heat exchanger (oil to water) in a car that doesn't have one.
Just be wary of your oil temps, my old RB25/30 with only a oil to air cooler only ever got to 90掳c after being up it for a while, that was without a thermostat, during daily driving my oil was never really at optimal temp, unless it was on the track. I ended up making a blanking plate for the front of the oil to air cooler for daily duties.
My STI had a oil to water and an oil to air cooler with a thermostat (although even with the thermostat closed it still flows some oil), it took at least twice as long for the oil to get to temp, during cold weather the oil could take up to 15 minutes to get to temp.
Have you worked out what size oil to air cooler you need to have the oil  in it's Goldilocks zone?
Disclaimer: you may be all over this, my point is I've spent a few years of finding out how not to have my oil temps running in a safe place, or, having to drive like a nanna for 15 minutes because my oil temp takes that long to warm up, from my experience the minimum oil temp of 90掳c should be seen before the loud pedal gets a work out, unless you like replacing bearings that is, ......apparently...  ,,?????
  • Like 1
GREX plates all have thermostats in them, so it's not that bad, I also run a 25 row Setrab oil cooler (overkill, was like $50 to get the larger one, so why not? LOL)
What you can do on cruise/idle areas of the map is run heaps of ignition advance to warm up the motor quicker. Many OEM cars do this to speed up warming up the coolant (do it within moderation).
  • Like 1
  On 18/07/2018 at 2:13 AM, r34unit said:
Would definitely be in trouble if the center bolt came loose @Dose Pipe Sutututu
i didn't take what size oil to air cooler you need to have the oil  in it's Goldilocks zone in consideration  @mlr
Expand
How was your oil temps before?
Expand
same, fresh build, larger oil cooler (19 row to 25 row)
However in the past, oil would be about 85~100 on the street, and hard out at Wakefield on a 35 degree day would peak about 120 degrees after 6~8 hard out laps.
Expand
Seems like you have a good hold on your temps.
You got a big sump??
I am also curious about the pressure relief, considering the oil pump has a relief valve to control pressure what is the intended purpose of this one? Is it there to prevent the oil filter from being over pressured?
I would not be concerned with the centre bolt coming loose considering a correctly tightened oil filter does not come loose.
Expand
Before motor went kaboom, stock sump overfilled by 1L
Now, 7L ASR baffled sump because I am stupid and spent too much money on my R33 and should have just bought a fast stock car.
Expand
LOL, I resemble that
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
