Forged rb25 & gearbox setup
selling up as there is not enough racing up here and CBF throwing more $$$ to finish it off
Built RB25 by Red R Racing in 2010 i think. I purchased off another forum member end of 2011 with 1500kms and i have done maybe 6-7000kms
Selling as a complete package only  I will be parting the rest of the car once this sells first. Currently in the car not running as I sold the loom and ecu.
rb25 s2
mahle pistons, spool rods
balanced & grub screwed crank
grout filled
nitto oil pump
ross metal jacket balancer
n1 water pump
oil restricters
head to sump oil drain
greddy plenum with q45 TB- ceramic coated silver
gt3076r ex/w .82- ceramic coated silver and black
Externally gated standard exhaust manifold (Jan 2018)
custom enlarged sump with tomei copy baffles
Turbosmart 45mm wastegate (New Jan 2018)
tomei poncams
tomei valve springs
heavily ported head
ARP headstuds
rb26 engine covers
mines cam cover baffles
xspurt 1000cc top feeds
gtr fuel rail
nismo fuel reg
splitfire coil packs
setrab oil cooler with themostat
rb25 g/box
r33 master cyclinder
exedy ceramic button clutch
1 piece 3inch tailshaft to suit s13
HEL braided clutch line
starter motor
Located in Townsville North Queensland
$9000 plus freight for everything listed. Non local buyer it will be loaded onto a pallet with a tyre under it.
NOT NEGOTIABLE STUPID PM's WILL GET STUPID REPLY's
build thread here
 Share
    • For students aiming for top grades, our Best Assignment Help offers the perfect solution. Our team of experienced writers delivers meticulously crafted assignments that meet university standards. We prioritize originality, timely delivery, and round-the-clock support to ensure your academic achievements.
    • I should clarify that the previous owner put the wheels on, so Im not entirely sure what he bought. I was searching the Rota page and found these two as the only matches. It did not occur to me that perhaps they sell these wheels with different offsets. I guess the best way to solve this is to take the wheels off and measure them from the inside to be sure.
    • The offset doesn't really have anything to do with dish directly. I mean it kind of does but it also doesn't, it's only tangenial. The offset is purely how much offset (get it) the mounting face is from the CENTER of the width of the rim. I.e, the mounting face would be directly in the middle of the 9.5inches if it was a 18x9.5 ET0 rim. Given it is a +12 rim, the mounting face is 12mm further away from the center (to the outside of the car). Your fronts are +30, so the mounting face is 30mm further away from the center (to the outside of the car). I would wager this doesn't look right, because most skylines generally have the same with guards front to back. So I'd think your fronts look significantly more sunken in than your rears. I'd wager by about 18mm, or so.
    • My '96 r33 Skyline has Rota GTR, 18 x 9.5 inch, ET30 on the front and Rota GTR-D, 18 x 9.5 inch, ET12 on the rear. (Put on by previous owner) The 12mm offset is throwing me for a loop. Is it due to the "deep dish" design of the wheel that the offset it so low? Or is it actually that low on the rear normally? If I were buying a set of new wheels, could I put 30mm offsets on the rear and reasonably expect them to fit? I have GTR Brembos and 370Z rotors (355mm/350mm) if it matters. Thank you.
    • here is the video, again really hard to hear but in person its very loud 20240703_175734.mp4
