Hi guys,
sorry I know parts of this have been covered and it has been a massive help!! Although I have an issue:
i have an rb20det in my s13, there are no looms in the car apart from the engine loom & fuel pump wires.
All plugged in and I have 3 power wires into the ecu & 6 ground wires out of the ecu; the car turns over and has injectors tick and fuel spray when fuel relay activated but I have NO SPARK.
i have power, earth and signal continuity from the ecu going to all the coils, cas and injectors; ami missing something from the ecu to tell coils to spark?
i swapped the igniter for a working one(same issue), should I try swapping cas and ecu?
thank you guys and sorry if I can’t find the info.
regards,
kev ?
https://www.sau.com.au/forums/topic/474606-rb20det-stand-alone-factory-unit/
Entirely possible the ECU's ignition outputs have been fried.  Try putting a test light from power to an ignition line from the ECU (at the ignitor would be convenient and see if you even get a flicker of light when the ECU should be switching the output to ground.  Pulsewidth might not be enough to get a glow, but if you do get a glow, at least you can assume that that ECU output is working.
Thank you mate, I’ll try that now and see how it goes, would it be best to mock up a led test light due to low voltage?
If you know anyone with a portable LCD CRO or are willing to buy a cheap USB one for your phone, you could test the waveform more thoroughly.  Otherwise, you may be into the realm of swaptronics.
Actually, if you have or can borrow an analogue multimeter, you might see something on that.  It should sit at 12V (if you probe the ignitor connection from the ECU with the other side of the meter on earth).  If the ECU pulls the ignitor down to earth, even briefly, it might be enough to make the needle flicker down from 12V.
Hey guys, update on the thread- now I have spark (ignition switch wire at the ecu needed relay power to it?)
now I don’t have an injector pulse haha. Injectors have power at each side however it’s not being switched via the ecu; would this happen if the timing was180 degrees out? I ran a new relay to feed the constant injector line, but still no good. Ecu is earthed at pin 107,108 and 116. Also 50 &60
have I missed something or do I ha e a dodgy cas or ecu?
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
