im looking at buying a 1995 R33 Skyline. The car is 7/10 condition for its age and is pretty much completely stock. i went and inspected this vehicle but the build plates are missing and the import sticker has been removed and has left the void writing on the car. The cur is registered with vicroads and will come with a RWC too. looking up the rego on vicroads it says the compliance plate date is not available.  ive been told that as the long 17 alpha numeric VIN is stamped on the struct tower/ chassis both aren't needed. though im worried that if the car was to become unregistered for what ever reason i wont be able to re register it again. or that ill end up getting defected by the cops should they check. Can someone help me understand this better as im struggling to find much info on the subject.
  • 4 weeks later...
  • 1 month later...
SO long as you can prove previous rego its not an issue
I would no a PPRS as a minimum or call DOTARS
Fine for not doing is about $100,000
They made me crush a JDM back in 2005 as it had been imported and left illegally
Lots guys getting cars in illegally and now the asbestos compliance has hit home its a minefield.
Buyer Beware.
Buy with head not heart.
Buyer Beware.
I know this is a little touchy, but care to elaborate on what happened and did they give you any compensation for crushing your car?
A mechanic told me the government are trying to cut down on car parts with similar effects to asbestos such as fibreglass where drilling into them could release cancerous powder. Is all this possible?
  • 1 month later...
A car without a compliance or build plate is going to give you trouble every time you try to do anything with VicRoads or if you get pulled over even if it is legit.
Obviously it's up to you but, i would walk away from this one. (<my two cents).
A car that comes into the country and doesn't get  ADR'd and a vin stamped and issued within a certain amount of time must be crushed, no excuse needed. Contact the department of infrastructure for further clarification as they handle all matters regarding imports. The department liaised with Vicroads for me when I had trouble regarding missing paperwork, and was the only way I was able to register the car. Vicroads do not understand the numbering system.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
