im looking at buying a 1995 R33 Skyline. The car is 7/10 condition for its age and is pretty much completely stock. i went and inspected this vehicle but the build plates are missing and the import sticker has been removed and has left the void writing on the car. The cur is registered with vicroads and will come with a RWC too. looking up the rego on vicroads it says the compliance plate date is not available.  ive been told that as the long 17 alpha numeric VIN is stamped on the struct tower/ chassis both aren't needed. though im worried that if the car was to become unregistered for what ever reason i wont be able to re register it again. or that ill end up getting defected by the cops should they check. Can someone help me understand this better as im struggling to find much info on the subject.
  • 4 weeks later...
  • 1 month later...
SO long as you can prove previous rego its not an issue
I would no a PPRS as a minimum or call DOTARS
Fine for not doing is about $100,000
They made me crush a JDM back in 2005 as it had been imported and left illegally
Lots guys getting cars in illegally and now the asbestos compliance has hit home its a minefield.
Buyer Beware.
Buy with head not heart.
Buyer Beware.
I know this is a little touchy, but care to elaborate on what happened and did they give you any compensation for crushing your car?
A mechanic told me the government are trying to cut down on car parts with similar effects to asbestos such as fibreglass where drilling into them could release cancerous powder. Is all this possible?
  • 1 month later...
A car without a compliance or build plate is going to give you trouble every time you try to do anything with VicRoads or if you get pulled over even if it is legit.
Obviously it's up to you but, i would walk away from this one. (<my two cents).
A car that comes into the country and doesn't get  ADR'd and a vin stamped and issued within a certain amount of time must be crushed, no excuse needed. Contact the department of infrastructure for further clarification as they handle all matters regarding imports. The department liaised with Vicroads for me when I had trouble regarding missing paperwork, and was the only way I was able to register the car. Vicroads do not understand the numbering system.
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
    • Maximum Attack has entered the chat
