I have a 1993 R33 gtst skyline
My passenger side window has stopped working, it goes down but not up
I have bought another switch, didn't work, new motor and relay which also didn't work. Took to auto elec and he reckons its been wired to suit a dodgey switch and can't handle a new switch.
I recently found that the earth wire for my boot fuse box had been rubbing against my subwoofer box and the wires were showing which earthed out my headlights, so could this be the problem causing my windiw issue?
Any ideas on causes apart from this?
And how can i manually wind up my window as its sitting down a bit from having window switch tested and it wouldn't go back up (I've disconnected motor)
https://www.sau.com.au/forums/topic/474612-manually-lifting-window-motor/
I'd get a second opinion on that, doesn't sound right to me.  If your switch works [test with a multimeter] and your motor works like ADMS15 suggests then its not been 'wired to suit a dodgey switch'.
  • Like 1
It’s been tested and it worked, I ordered a new one just in case and that worked fine, I put it in the car and it still wouldn’t go up, only down. The motor is fine, relay fine then I don’t know, I’ll try what ADMS15 suggested and see what happens because I can only now put it down to wiring
I was told by first auto electrician that the earth for the “up” part of the switch wasn’t working but it was a good earth going down if that makes sense
Any auto sparkie worth his salt can run a new earth strap.  So I'm concerned...I'd still be getting a second opinion.
  • Like 1
I suspect that what was meant is that when the switch is moved to "up" it successfully connects the terminals together (and given that these things switch on the earth side, that means that it provides an earth to the circuit) and that that does not happen on the down side of the switch.
If it were me, I would disassemble this switch and investigate what is not working inside.  I have done this several times with the headlight switch in my car, because they tend to get a bit dirty from arcing as they open and close.  I'd be sure that the window switches would also be dismantlable, and could be cleaned, or new brass strips made (if needed) or even plastic repairs done with epoxy or (appropriate) superglue to make it work.
  • Like 1
What about the power window module in the door? I havent seen anyone mention that
They play up sometime. If the motor works (which it does) and you have tried 2 x new switches then i would assume it would be the power window module
  • Like 1
Is this the black relay box on the drivers side door?
    • This is the GTR fuel pump. Yellow shows 12V, orange shows earth. The ECU provides the earth to activate the fuel pump relay. The ECU side of teh relay will pull low when the ECU activates. This is the RB20 fuel pump. Almost the same, but a little simpler. You can see I indicated (above) where the 12V line goes down to the RB20 diagram on the overall diagram, whch shows both RB26 and RB20. This is where I show it coming in on the RB20 diagram below. You can see that the dropping resistor is handled differently. When the fuel pump control is not providing earth to the pump, the pump earths through the dropping resistor and thus runs at lower voltage (some is wasted over the resistor) and runs slower. I showed that "not 12V and not quite earth" portion of the wiring in a paler orange. The rest of the wiring that I did not colour on that little section below the pump would be orange when the fuel pump coontroller is providing earth. This drop is handled inside the fuel pump controller in the GTR. Regardless, you can see where 12V is supposed to be, where earth is supposed to be. The key on prime is via the ECU providing the pump for only a few seconds the switching off. You should be able to see that happen.
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
    • They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
