Dose anyone do work on r32 gtr in the southern suburbs. south oz.  ( that’s knows what there doing). Getting to boost works is a head f—k. Plus  feel like I’m paying more cos of the gtr  badge. They are good tho. Just to hard to get to.
https://www.sau.com.au/forums/topic/474613-r32-gtr-worked-just-a-bit/
1) poor man pays twice
2) knowledge is priceless
3) poor man pays twice
  • Thanks 1
  • 3 weeks later...
Shaun/Boostworx is one of best bang for buck in Adelaide. You will be very hard pressed to find anyone else with the same level of knowledge and skills, particularly when it comes to more involved modifications or fault rectification. And good luck find anywhere that offer a complete in-house service at such sensible prices.
  • Thanks 1
  • 10 months later...
  • 1 year later...
My 32 some how ended up at mt baker( a mate said they were good) 6 month later got my hand on it ran like shit n lost over 150kw. Got pissy over it. then to custom imports. They fixed his shit changed some bits. Bang its back to old power n boosting like a rb should n smoking n chopping shit like it should. Yer boy
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
