Ashley33 Posted August 1, 2018 Share Posted August 1, 2018 Hey guys, been trawling through every forum trying to find diagrams and pictures to help with wiring an auto to manual conversion for my R34 GTT. Have done everything apart from wiring. I have read a thread but had no pictures. Think I've done all the gearbox wiring correctly, however, struggling to find the inhibitor switch. Anyone who's done this should be able to help me? Some are saying inhibitor switch is by the fuse box but still unsure? Thanks in advance. Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/ Share on other sites More sharing options...
sean133 Posted August 4, 2018 Share Posted August 4, 2018 Can you explain what wires you connected for the neutral and reverse switch? Inhibitor is joining black and pink to the grey wire Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882527 Share on other sites More sharing options...
Ashley33 Posted August 4, 2018 Author Share Posted August 4, 2018 Got the inhibitor switch working. Id have to get photos a bit later. There’s a brown and black plug from the auto box speed sensor. Not sure which one to use. And then a black and green sensor from th PNP switch. Green isn’t used. The black one you use red wire and a ground wire from the speedo sensor for the reverse. Just need some photos to follow really. Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882528 Share on other sites More sharing options...
sean133 Posted August 4, 2018 Share Posted August 4, 2018 Yeah I tried that it didn’t work photos if possible would be really great thanks! Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882533 Share on other sites More sharing options...
sean133 Posted August 4, 2018 Share Posted August 4, 2018 Here’s my loom and the 4 wires from neutral and reverse Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882534 Share on other sites More sharing options...
Ashley33 Posted August 4, 2018 Author Share Posted August 4, 2018 So is yours working or are you still doing the conversion? Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882535 Share on other sites More sharing options...
sean133 Posted August 4, 2018 Share Posted August 4, 2018 My manual conversion is done apart from wiring up the reverse lights and neutral switch Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882536 Share on other sites More sharing options...
Ashley33 Posted August 4, 2018 Author Share Posted August 4, 2018 Yep same. We are in the same boat. Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882537 Share on other sites More sharing options...
sean133 Posted August 4, 2018 Share Posted August 4, 2018 Reverse lights - red to red, other wire goes into the black/pink and grey , 3 wires connected speedo straight swap with the auto speedo neutral switch is the only one I havnt worked out now Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882543 Share on other sites More sharing options...
Ashley33 Posted August 4, 2018 Author Share Posted August 4, 2018 Isn’t there 2 Speedo sensors from auto box? Which one did you use? Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882544 Share on other sites More sharing options...
Ashley33 Posted August 4, 2018 Author Share Posted August 4, 2018 Can you send some pics? Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882545 Share on other sites More sharing options...
sean133 Posted August 4, 2018 Share Posted August 4, 2018 Speedo- yellow to brown grey to black whichever plug that makes sense for Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882547 Share on other sites More sharing options...
Ashley33 Posted August 4, 2018 Author Share Posted August 4, 2018 Hmm not really sure what you mean. Will be working on the car tomorrow so hopefully can get an idea once looking at the wires. Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882548 Share on other sites More sharing options...
Ashley33 Posted August 5, 2018 Author Share Posted August 5, 2018 Hey mate, got the reverse lights sorted. Cheers. Can’t get the Speedo working though.. we tried yellow to brown and grey to black but didn’t work. Any help? Are they the correct wires? Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882577 Share on other sites More sharing options...
sean133 Posted August 5, 2018 Share Posted August 5, 2018 Read somewhere s1 to s2 box the wires are opposite try yellow to black perhaps? Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882579 Share on other sites More sharing options...
Ashley33 Posted August 5, 2018 Author Share Posted August 5, 2018 Nope.. Tried both auto speedo connectors and tried both wires and tried them opposite ways and nothing which is quite annoying! Your reverse wires were spot on though cheers! Might have to get it finished off by an auto elec, unless you got photos or something? Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882583 Share on other sites More sharing options...
Kinkstaah Posted August 6, 2018 Share Posted August 6, 2018 I remember vaguely (months ago) when I did this, I initially hooked the R33 GTST speed sensor into the wiring loom for the wrong auto speed sensor, as you have described the R34 GTT auto loom has wiring for two sensors as the auto has two "speed sensors". Unfortunately I'm in no position to get under my car and check it out, but I do remember getting it backwards and going 'aha' upon consulting both diagrams (i.e manual gtst box and R34 GTT) Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882618 Share on other sites More sharing options...
Ashley33 Posted August 6, 2018 Author Share Posted August 6, 2018 Hey mate, cheers. Not really sure what do to as I’ve tried both speedo sensors. It’s literally just two wires joined to two wires so I don’t know what’s wrong? Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882647 Share on other sites More sharing options...
sean133 Posted August 6, 2018 Share Posted August 6, 2018 could be a problem elsewhere? Cluster ? Even the speedo itself Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882663 Share on other sites More sharing options...
sean133 Posted August 6, 2018 Share Posted August 6, 2018 Did you fit a manual cluster or still got the auto one in Link to comment https://www.sau.com.au/forums/topic/474625-r34-manual-conversion-wiring/#findComment-7882664 Share on other sites More sharing options...
