OK so need some help please people just turbod my na r34 and am checking if what it's doing is OK before my tune on Thursday OK so I'll start with parts I'm running... And post problem last
Rb25de neo
R33 5speed gearbox conversion
Was using rb25 one but think was near dead New rb25turbo hasn't arrived yet
R33 turbo manifold
Gtt injectors
R32gtst4det fuel pump
Power FC ecu stock gtt base tune atm
Big front mount cooler
Turbo smart bleed valve
New 3"pipe decat and r32 custom dump
R34na 02sensor
R32gtst4det afm I wired in also tried 34 na one OK so my problem is it misses bad under boost only.. disconnect turbo runs sweet can this be my ign timing when boosting?  Just want it all good and ready for my first tune as never had one what should I get done in the tune and what boost 5? And just get fuel/air and some timing pulled/retard etc...also haven't tried yet as my new turbo is on its way but the one I was using was blowing smoke and whining and no matter what it was stuck on 7-8 psi my hand controller wouldn't turn it down so waste gate? Over boost could've been the problem?
Edited by R34 rocket bunny sedan
https://www.sau.com.au/forums/topic/474642-r34-naturbo-conversion/
