What are some best recommended machine shop and engine builders for RB Motors. Need some names and contacts to start researching, ones I found on this site seems outdated.
Looking for ones that can also do CNC head porting.
Edited by etang789
In Oz or Honkers?
In Oz, Lewis Race engines in Adelaide would be a good choice.  As would Knight Engines, but he is usually flat out booked for a year or so in advance.
I'm betting that if you did just a little googling you would find the 6 or 8 highly recommended shops in the eastern states, and the one or two really good ones in Perth too.
As for CNC head porting.....waste of time unless you're wanting to do multiple heads (like dozens) and want to bring the per unit cost down.  If you want the best port job, you still need to finish a CNC job by hand, because CNC porting has to be quite conservative to avoid problems caused by core shift etc etc.
JHH, CNC heads.. Very sex
Or there's PMC, one man shop and he hand ports but it looks as though a robot is doing it (he is that good). Has built many race winning engines for WTAC.
Depends how deep your pockets are.
On 8/5/2018 at 8:21 AM, GTSBoy said:
In Oz or Honkers?
Looking for a shop either in Australia or New Zealand.
Thanks! will talk to Lewis Race engines and Knight Engines.
Yea I searched a few but some information seems outdated no longer in business or no recent job references thats why Im asking here.
In NZ Robbie from RIPS has a rock solid track record building his own and customer's engines. Does a lot of exporting - builds cars for English Premier League players (so not bargain basement builds) but worth getting a quote:
https://www.ripsracing.com/
  • 4 weeks later...
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
