5 hours ago, Ben C34 said:
I'd change the cabin filter never
Depends on where you're driving around, I guess. Have you ever taken a look at yours? After 50,000km (22,000 of which were in Japan), mine was black. Good thing I had a couple of Fram cabin filters spare.
5 hours ago, doggido said:
I was getting the occasional wif of old stodgy socks when on & now it smells of new!
It's easy to see if it needs changing. You just need to pop out your glovebox to get in there and check if it just needs a bit of tapping out or if it's too far gone and needs to be binned. But yes, the stench was a vital clue.
  • 1 month later...
Check vacuum advance operation????  the 1970s want their service book back...
Check and adjust throttle position sensor?  are these even adjustable?
Also, does anyone ever check valve clearances are part of regular servicing?
  • 1 month later...
fairly sure my TPS is not adjustable, there is an ECU adjustment procedure for it to re-learn the throttle closed position.  So it is more of an electronic adjustment than a physical adjustment of the sensor itself.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
