R34 Radiator fan issue
I'd be using your approach if I had the light. Some measuring, get some vernier calipers, measure, draw, make another one as a slightly smaller hole and start cutting.
Hi guys really sorry if its a silly question, but im trying to figure out if a r33 gtr front reinforcement bar will fit on a r33 gtst series 1. Need it for road worthy but also wanted to get the gtr one as I wont need to cut the reo when I upgrade my fmic apparently? TIA!!
For a more simple method you could look into Dakota Digital and see if their cruise control retrofit kit would work on the stag.
In which case I still think my approach would be just as easy. In fact, easier, because of all that guidance on the front side.
I would be very surprised if you could tell the difference between 8kg and 12kg wheels in a blind A B test. What you will be able to notice is going to wider wheels (+wider tyres). If you don't have to abide by any rules, I'd fit the widest wheels you can get under the guards.
