For those that did not know, we are the Australian distributor for Megan Racing. We've just landed a shipment which is mainly suspension arms. There is a bunch of stuff for Nissans and we can do deals for SAU members of course.
Go to www.moonlightracing.com.au and have a browse around, any queries or anything in particular you're after just let me know.
https://www.sau.com.au/forums/topic/474708-megan-racing-in-stock/
  • 3 weeks later...
Thanks for the heads up but I'm not seeing much in there for V36 Skylines. Have Megan Racing reduced their product line in recent times or something?
They seem to have a few things on their website for G37? (Its the same as V36 isnt it?) American companys always under Inifiniti
You're right and that is what I was looking for, given the products were seemingly a copy and paste from the Megan site but still, not much in there.
Love my Megan Racing muffler. Just the right note without taking away from the vehicle's elegance.
11 hours ago, Driftqueen12345 said:
Hi guys do u have any toyota soarer supra suspension
What specifically? We have arms in stock yeah but not coilovers from Megan. But can do coilovers from other brands no worries
16 hours ago, Driftqueen12345 said:
Thanks for letting me know ended up picking up set of BC coilovers with the soft hard setting on top of them should do the trick so confused all this stuff so many different ways brands ect
For sure, no worries we can supply BC as well if you have any requirements in future for bits just be in touch.
  • 3 weeks later...
  • 6 months later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
