2003mdl Autech Axis 209KW AWD 2.5lt turbo 145 000km . Very good condition for age. Some minor Knicks and scratches, nothing big.
Totally stock standard except for front brakes which have been upgraded to r34 gtt 4 pot callipers and 310mm discs, intima sr front pads and remsa rear pads. Will also come with standard brakes if you want them. Also fitted with roof rack and alarm/immobilizer.
Turbo was replaced at 135k km with a low km (65000) standard unit, oil feed was upgraded to a braided one at the same time. Plenty more life in this turbo.
Autech cream leather interior with heated front seats. Ac climate control works beautifully. Has aftermarket Android 5.1 head unit, cd/dvd/nav/obd reader system with 2017 navteq maps and hobdrive obd software connected to factory bose sound system.
Spark plugs and diff/transmission fluids replaced at 120k and wont need to be done again till at least 200k. Coolant done at 140k. Engine Oil and filter will also be replaced prior to sale. I have serviced this car personally and oil has been replaced every 5k km using penrite synthetic. This car has been well looked after and has plenty of life left in it. Myself and previous owner are both sau members who have treated this m35 well.
The only negatives are rear split window in the tailgate doesn't open (possibly the switch), rear tailgate struts need regass or replace. A squeeky bush in the front suspension (only in really cold weather)
Reg till 31/10/18 $6200 as is or $6800 with RWC. Located in s.e suburbs of Melbourne.
These are old pics but still looks the same. Will update with current pics when i get some time.
https://www.sau.com.au/forums/topic/474744-m35-stagea-autech-axis/
  • 4 months later...
Back up for sale. Now has reg till 31/10/19. Price is now $6500 with reg and plates, no rwc. 146 700km on the clock. Has just been detailed and will gave fresh engine oil and filter. I will also include a few spare oil filters i have.
Some current pics.
IMG20190119200207.jpegIMG20190119200004.jpegIMG20190119200137.jpegIMG20190119200105.jpegIMG20190119200353.jpegIMG20190119200506.jpegIMG20190119200909.jpegIMG20190119200926.jpegIMG20190119200951.jpegIMG20190119200902.jpegIMG20190119200729.jpegIMG20190119201005.jpegIMG20190119201235.jpegIMG20190119200547.jpegIMG20190119200739.jpegIMG20190119200825.jpegIMG20190119200804.jpegIMG20190119201404.jpegIMG20190119201409.jpegIMG20190119201431.jpegIMG20190119200531.jpeg
Bump. Just serviced, fresh oil and filter. Will come with 4 new oil filters and a new set of front brake pads for the r34 callipers. Will also come with stock m35 front brake setup.
Price dropped to $6000 with reg or $5500 without reg for anyone interested from interstate. Great reliable car, come and get a bargain.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 2 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
