1593609333_Coils-PhotobyLeonDamon_edit02.thumb.jpg.1d074f24f11db7ac13e41a619639f30a.jpg
5-0 Ignite is proud to offer SAU members and Nissan enthusiast an alternative option for 100% plug and play coil pack upgrade, utilizing Audi R8 coils, that are known to perform without breaking the bank. We aim to solve common problem of spark blow out at high boost levels as often experienced by many owners which often resulted in dyno down time, performance/efficiency sacrifice, running ridiculously small spark gap and associated costs. We were hugely satisfied with the R33 GTR test vehicle running our kit which yielded 603 whp @ 27 psi with off-the-box 0.9mm BKR7E spark plug gap with plenty more to go, more on that here: https://www.50ignite.com/blog/technical-blog/coils-aint-coils/, (we couldn't achieve this on the previous 2 different brand coil setup).
All of our products are designed, manufactured and tested here (except for other manufacturer's buy-in product) in Perth, Western Australia. We are slowly expanding our product lines with items that we consider as 'worthy' or supporting upgrades. For now, we have these kits on offer:
  • R32 GTST - RB20DET
  • R32 GTR - RB26DETT
  • R33 GTST - RB25DET S1
  • R33 GTST - RB25DET S2
  • R33 GTR - RB26DETT
  • R34 GTT - RB25DET NEO
  • R34 GTR - RB26DETT
  • S13/S14 - SR20DET
  • S15 - SR20DET
Check out the full product line on offer here www.50ignite.com at introductory pricing.
Additional information and features
Our RB to Audi R8 coil conversion harness features;
  • 100% Plug and Play. Remove your old OEM loom from the connectors, plug your new one in.
  • Bypasses the OEM igniter completely (where applicable).
  • Teflon F.E.P wire insulating material capable to withstand higher temperatures than OEM PVC insulation and resistant to most oils and chemicals.
  • 2.0mm2 wire conductor cross section area for the constant power and power ground.
  • 1.5mm2 wire conductor cross section area for signal and signal ground.
  • OEM specification weather proof connectors.
  • P.E.T wire braided sleeve and connector boots.
  • Heat shrink with built in glue for good adhesive strength.
  • Professionally crimped terminals.
  • Separate power ground and signal ground terminals to avoid ground loop.
  • 2-step cross-checking process, bench tested and tagged to ensure a guaranteed start and product traceability.
If you have made variations to your setup (i.e. engine conversion etc) please check your ignition loom and cross reference the main connector to our pictures on the website. Should any part of the loom be close to any part of the exhaust, it must be moved or sufficiently protected from thermal damage.
We do not incorporate a wire loop in our harnesses for use with an inductive timing light as our experience proves it to be an unreliable source. To set ignition base timing, we recommend the use of coil on plug extension lead (such as DAT-Equipment TE010 or the like) to latch your inductive clamp onto for a much more reliable reading.
Our RB20/RB25/RB26 conversion mounting plate features;
  • Direct bolt on with all fasteners provided.
  • Coil packs can be removed individually from the mounting plate when installed.
  • Correct indexing of coil pack placement.
  • Provides lateral support on the upper body of the coil pack (removes dynamic bending stresses on the fragile spark plug in comparison of when no mounting plate is used).
  • Precision cut Aluminium plate.
  • Stainless steel stands.
  • Incorporates loom holder for a clean ‘tucked’ look.
The coil packs we feature;
  • 100% genuine Denso Audi R8 ‘smart’ coils. Trust the Japanese brand.
  • Coil packs have built in igniters.
  • Made in Italy, sourced from a reliable supplier. Manufacturer’s 1-year warranty.
Shipping available worldwide, trackable and insured.
For further information/orders, head to www.50ignite.com or send an enquiry to [email protected]
  • 4 weeks later...
Can the coil cover be installed while using these? On Rb25 neo using gtr covers..
Also what are the opinions on when something like this is required over oem or splitfire?
The valley cover cannot be used with the conversion kit.
Good set of OEM or splitfires are fine if you have a mild build but the limits will be found when you start pushing higher boost/power and realise you have to tighten the plug gap down severely to 0.5mm or 0.4mm in some cases. Big HP lads upgrade to Audi R8/LS/R35 coils for that reason so they don't suffer from combustion efficiency problem or spark blow out running at optimal gap.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
