Hi All,
I am trying to finish off my build on my R34 RB25DET NEO and want to make sure what i have going on with my coolant lines wont cause any stagnant flow or air pockets.
I am running a plazmaman Intake manifold and throttle body, and also a Haltec IACV so i dont have any coolant lines running to those.
I have the turbo coolant returning to the back of the intake runners (Orange cable tie)
And i was going to cut the nipples of the top of the runners and tap and plug those (Blue/Yellow, Yellow/Yellow)
And also Plug next to the thermostat housing.
Does this sound alright or am i going to have stagnant flow and airpockets in the intake runners?
The other option is for a swirl pot, but in the strive for simplicity and aesthetics i would rather not install one unless needed.
Cheers,
Edited by BlackBox
I suspect it would be wise to use at least one of those top-of-water-runner fittings you plan to nuke as a bleeder.  On a Neo, the rear one goes to the IACV which is a bleed point, and I think the front one is a bleed on the front end of the plenum too, no?
It has been that long since i first started i cannot remember where the coolant lines originally ran however the oem bleed points are no more.
It would be easy enough to tap a thread and install something like this, but i am looking for the best and neatest solution,
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
