Replaced two of my power steering lines between the reservioir and chucked a seal kit in the PS pump. Now I have no Power Steering. The Hicas diagnosis comes up as Error 22 - Steering angle sensor.
My question is, is the Steering angle sensor the clock spring?
My car is a series 2 r33 GTST with no modifications to the steering system. I still have Hicas and the stock steering wheel.
Nope.  Clock spring is the mechanism for making the indicators latch and release.  Steering angle sensor is a separate thing.  They can die.  The little pin from the steering wheel that engages the sensor and drives it around can possibly break too, or if some hamfisted bumblef**k has had the wheel off and not put it back on correctly, then simply not engaged.  It needs to read zero angle while the car is driving straight or it will eventually go into fault, because the car literally cannot hold a set steering angle while >5km/h for more than a few seconds.  The sensor is expected to continually change value, or fault out.
So that yellow ring is what I’m calling the clock spring, am i wrong in calling it that? And the steering angle sensor is deeper into the steering collum somewhere?
I’m having troubles finding what steering angle sensor actually looks like.
No, if I had to guess, I'd say the exact opposite.  The clockspring will be deeper down.  The SAS would be right at the top, because there is a pin off the back of the steering wheel hub that drives it.  At least, that's how it is on the R32.  I've never pulled the wheel off an R33.  In fact, it doesn't matter, because I only had a car with HICAS on it for a very short time before I taught myself how to take off and nuke it (HICAS) from orbit.  It's the only way to be sure that it won't f**k up your life.
This is what the top of an R32 steering column looks like.  SAS is what you're seeing.
Edited by GTSBoy
Small correction.  A lot of people also call the commutator that passes wiring into and out of the steering wheel (ie, horn buttons, cruise control, stereo buttons) the clockspring.  It is quite possible that this is common to steering angle sensors on newer cars.  On R32 at least, the only wire coming into the steering wheel is for the horn.  You can see that connector on the lower left of the photo above.  The drive pin for engaging the steering wheel is opposite.  I guess that makes the SAS the "clockspring" on this too.
The photo I posted has a pin too. It’s approx at the 9 o’clock position. Thanks for all the help.
  • 5 years later...
I haven't been able to find much info but what happens if the sensor dies out? I assume mine is fine considering that I've driven well over 70km an hour and I haven't experienced any faults yet (not that I adjusted it or anything). Is it even possible to adjust the steering angle sensor the wrong way without removing it?
The reason I ask is because there was a time when I turned the steering wheel with the nut removed (not sure if this moved the shaft and the steering angle sensor separately but I assume not).
I know that it turns with the steering wheel and the shaft.
Edited by silviaz
  • 9 months later...
So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
Edited by silviaz
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
    • Yeah, but "restomod" implies Singer and things like it, which implies drug money / trust fund maturity.
