Hi all, I’m new here and new to skylines in general. I just got an R33 GTS-T RB25DET.
The previous owner only had it for about a year and wasn’t very mechanically minded and couldn’t tell me much of what was done to it by the owner before him. Long story short I’m having an issue with the revs dropping when I’m coming to a stop with the clutch in. Neutral or in gear makes no difference. The revs slowly drop as per normal but 1/4 times they just go all the way to zero and it stalls. The car runs perfectly fine otherwise. This leads me to believe it’s a sensor issue. I have taken the air box out and cleaned the filter (looks pretty clean and new anyway) and I have sprayed about half a can of cleaner through the AFM. This made the car a bit smoother in the lower gears, but the stalling is persistent. I’ve read many things here before posting this, I’m really at a loss as to what to do. Reset the ECU? Check and clean more sensors? I don’t know.
as far as I am aware the mods done are:
- 3” straight through turbo back exhaust
- 14psi boost
- A front mounted intercooler has been fitted
- turbo timer
any help is appreciated, thanks.
https://www.sau.com.au/forums/topic/474785-revs-dropping-when-stopping/
Just an update for anyone else who might have a similar issue. The BOV was deleted and all the lines clamped. I replaced it with a stock intake pipe to the turbo with recirculating BOV and reverted as much of these dodgy amateur cable tie mods as I could back to their original stock parts and it runs ultra smooth with no issues now :)
Im even getting an extra 100km per tank on average, for a total of about 380km per full tank!
I never ended up cleaning the IACV, it’s on my to do list though. Cheers.
  • Like 2
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
