Hi all, I’m new here and new to skylines in general. I just got an R33 GTS-T RB25DET.
The previous owner only had it for about a year and wasn’t very mechanically minded and couldn’t tell me much of what was done to it by the owner before him. Long story short I’m having an issue with the revs dropping when I’m coming to a stop with the clutch in. Neutral or in gear makes no difference. The revs slowly drop as per normal but 1/4 times they just go all the way to zero and it stalls. The car runs perfectly fine otherwise. This leads me to believe it’s a sensor issue. I have taken the air box out and cleaned the filter (looks pretty clean and new anyway) and I have sprayed about half a can of cleaner through the AFM. This made the car a bit smoother in the lower gears, but the stalling is persistent. I’ve read many things here before posting this, I’m really at a loss as to what to do. Reset the ECU? Check and clean more sensors? I don’t know.
as far as I am aware the mods done are:
- 3” straight through turbo back exhaust
- 14psi boost
- A front mounted intercooler has been fitted
- turbo timer
any help is appreciated, thanks.
https://www.sau.com.au/forums/topic/474785-revs-dropping-when-stopping/
Just an update for anyone else who might have a similar issue. The BOV was deleted and all the lines clamped. I replaced it with a stock intake pipe to the turbo with recirculating BOV and reverted as much of these dodgy amateur cable tie mods as I could back to their original stock parts and it runs ultra smooth with no issues now :)
Im even getting an extra 100km per tank on average, for a total of about 380km per full tank!
I never ended up cleaning the IACV, it’s on my to do list though. Cheers.
  • Like 2
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
