Hello,
I am thinking of upgrading my fuel system to E85 and wonder what sort of power I will get with my -5 garrets?
I have to upgrade my injectors anyway to push these turbos further on 98 but will I get much more power going to e85?
Thanks
https://www.sau.com.au/forums/topic/474790-e85-twin-turbo-5-power-results/
Current mods are
-5's
Dumppipes
3.5 inch
Tomei pon cams type b
tomei valve springs/retainers/guides
mild port n polish
big sump
tomei oil pump
hks f con
Full built bottom end and balanced
Good radiator
Nismo intank pump
600cc Nismo injectors
Tomei FPR
Oil cooler
New mods.
Frenchys performance in tank twin fuel pump setup -8an
2x Walbro 450hp each e85 pumps
3 -8an 200 series fuel lines
TurboSmart FPR -8 AN
76mm Pro Plazmanm intercooler
Twin entry fuel rail
1650cc ID Injectors
Link g4 with ethanol sensor
Nice. Built as in forged or just rebuilt? And remains 2.6?
And you get yours with the -5's on it or did you install them?
E85 will be the juice of the gods for you! Keen to see the power curve with that setup when it gets up on the rollers. Also I feel you will be going single in no time at all!
eFully forged bottom end.  Tomei Pistons and Nitto Conrods.
does have stock crank.
still 2.6.
Yes well single turbo.....pockets are not that big at the moment.
The driver for this is to get rid of the HKS F-con V as no one  good can tune it in NZ now.  So if I am going to retune I may aswell set it up better.
with the 600cc injectors maxed I got 384KW ATW's but we pegged it back abit for the street I got about 375ish.  I have 30,000 KM's so far on this tune and build.  Soichi who was a legend here in NZ did fantastic work.
Edited by Stixbnr32
I got just shy of 500hp with a fairly tame -5 setup + e85 (details + dyno in build thread in sig if your interested), based on a recent tear down it's likely not all cylinders were round at the time ?
Best thing about e85 compared to 98 was filled all the shortcomings of the low-mid range the setup had, it took a fun, but laggy setup to something very usable in all situations.
Car should be back in a couple of weeks as most of the work is done now, so will be interesting to see what a fresh 2.6 with only a mild compression bump produces in comparison.
Still in NZ?  Who will be tuning it?  I'd expect with a decent fuel system on board you should be able to go WELL into the 400kw @ hubs range on their dyno, I'd say high 400s could be doable.  One of the lads I know cracked 500kw at DTech with his HKS 2530Kais with some ethanol on board on a good RB28 build :)
On 9/11/2018 at 8:55 AM, Stixbnr32 said:
Yeah still in NZ.  Hopefully one of the boys joe kyle or glenn suckling.
Joe doesn't tune. In Auckland now that Soichi has gone to Aus that really just leaves Glenn Suckling ...although there are tuners in Papakura and Pukekohe that I don't personally know).
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
