What part of Sydney are you in?  Just had the same done for my R34 by Mark at MRC Performance & Dyno in Castle Hill, very knowledgeable with all things RB, also the best troubleshooter i've been to, he's solved many issues other repuatable workshops either caused or hadn't picked up on.
They offer a really good health-check / inspection which includes a quick run on the dyno to make sure all is in order also, mention this as it's really worth the $120 odd dollars so you know what you're up against for future mods etc.
If it helps break the ice, mention Daniel with the black R34 GTR suggested you call.
https://www.facebook.com/MRCDynoServices
Edited by JGTC
What do you consider a major service?
If it's a basic fluids, plugs, filters type of thing invest in a good jack and some jack stands and do it yourself.
You will save thousands over time.
Nothing about it is hard.
If you cannot see yourself doing a timing belt, if that's required, any local good garage can do that, just get them to do the timing belt, water pump.
The problem with getting basic work done at "tuning shops" is that they cost alot of money, this is a fair thing though because you get what you pay for, usually, but that is really only required for their technical expertise, there is nothing technical about doing the basic service stuff.
Plus money saved can be better spent on parts, or shiny things for the missus to take her focus of the car parts that she found stashed in the garage.
Plus there is nothing more satisfying than working on your car.
Basic service parts cost around $100 - $150 dependent on parts required.
14 hours ago, eVo25t said:
I'm talking timing belt, water pump, gearbox oil, diff oil and probably needs a dyno run too. I'm stuck because I moved to a unit and dont have all my stuff anymore
I've never used one but here is an option, maybe, depends on cost though.
https://www.diyautogarage.com.au/about/
I always wondered about the legalities of such a business, cool idea though. I miss the days of servicing my car on the street in Elizabeth Bay getting death stares from all the hoity toity locals :4_joy:
  • Like 1
I would love to start up a shop like that, with a gym with only racks and free weights
Oh, and a bar
It would be just like my old garage, only without the comments of, "how long are you gonna be", "can you keep the noise down", "how much have you drunk", "do you think it's a good idea to drink and train/work on the car in the state your in".
That shit gets tiresome..
  • Haha 2
2 hours ago, r32-25t said:
Must wear safety glasses at all times, f**k that
Only a small inconvenience.
I actually aways wear safety glasses whenever I'm under the car, usually if I got shit in my eye working under the stands my head would bounce between the floor and some part of the undercarriage at least 10 times....
  • Like 1
    • Hi everyone, Apologies in advance if this feels like a topic covered multiple times. I'm only asking because some of the old topics I found are missing images now. I'm in the process of getting a manual boost controller (BC). Nothing fancy, just getting a manual one for now as I don't plan to go crazy with it and would not go over 10 PSI. My car is not jacked up on boost steroids to do crazy numbers. I want to understand the OEM setup of the boost solenoid and vacuum lines on the R34 GTT so I know what needs to be changed when I do install the BC. I sketched the current setup to the best I could see and it's on the diagram attached. If the boost controller 'Wastegate Arrow' goes from nipple 1 to 2. My understanding is that the red vacuum line's "F" connector-end should be connected to BC nipple #2? Nipple #1 is meant to have the "pressure source" so what vacuum line would that be? Is it the green vacuum line?  From what I have read here, the OEM boost solenoid is not used at this point. So that can come out and then I can just plug the nipple that usually connects to the blue vacuum line?  So would the final setup look something like this?   Thanks in advance. I don't want to already be knee-deep into pulling out vacuum lines before understanding this. I'm a noob when it comes to boost setups so trying to learn as I go.
    • Initial/early bite is a feature of.....generic pads. Things that work cold. Just put Bendix Ultimate in it. If you don't like them, it's only $3.50 wasted and an hour to change them. I've been using Intima SR, and they seem to be a good performance pad. Street friendly and able to take at least a little beating.
    • This is my first post after registering.. I hope i can find useful resources on this forum. Great forum.
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
